Old 11-12-2015, 05:00 PM   #1
Antdez
Drives: 2012 Golf R
2012 Golf R problem
Hey guys I don't post very often but about 3 months back I traded my GTI for an R with 25k miles and it has been great until today. When I bought it it came what I believe is Stage 2 had an APR sticker on the fuel pump and 42dd air intake plus I believe a new downpipe and GIAC tuner fully loaded with all the tunes. I bought a 35000 mile extended warranty and it came with a 6month 6,000 mile dealer warranty.
So fast forward today was driving on the highway not even pushing it going like 60 when all of a sudden car starts bucking and then goes limp like barely able to get to 60mph and check engine light comes on. So I am like a mile from a VW dealer and I limp it over to them. They check it out and apparently the Fuell Pump is broken the inside is all ground down and the Cam is messed up. VW says they can't fix it under warranty because of aftermarket but the dealership where I bought it is going to take care of it apparently. 3500$ repair VW said. Why did this happen and what should I do after the dealer gets done with it since they will probly replace the fuel pump with an OEM model.
TL/DR Owned car for 3 months and all kinds of havoc happening please help.
Antdez is offline   Reply With Quote
Old 11-12-2015, 05:19 PM   #2
rupertpupkin
rupertpupkin's Avatar
Drives: '12 CSG R
Cam follower failed and fuel pump killed itself on the intake camshaft. Have to keep up with the cam follower replacement. They typically will not warranty with aftermarket HPFP.
Since you bought it from a dealer with that pump already installed you got lucky.
rupertpupkin is offline   Reply With Quote
Old 11-13-2015, 08:51 AM   #3
project92raddoslc
project92raddoslc's Avatar
Drives: 2016 GOLF R
Moving forward you should change the cam follower every 10-15k miles to be on the safe side. I'd also suggest oil changes at a 5k interval rather than 10k miles.
Old 11-13-2015, 04:26 PM   #4
Antdez
Drives: 2012 Golf R
Thanks for the wisdom guys I didn't even know about that.
Old 11-13-2015, 08:56 PM   #5
pdxa4
Drives: Golf-R, former Audi D2 S8
Yep extra caution is needed for sure with the FSI engine. And the cam follower wear happens faster on the aftermarket high pressure fuel pumps. The APR pump has a very strong spring and is known for causing higher wear.
The advice above is correct with quality well chooses oil being changed every 5k miles, and one needs to change the follower every 10k.
I'm a low mileage guy, and I change it every 5k.
Current: Golf-R Rising Blue, Mazda MX-5
Former: Audi D2 S8 Ming Blue,VW mkV GTi United Gray
B6 A4 Avant 1.8TQ Atlas Gray
B5 A4 1.8TQM Santorin Blue J31-K04 Beauty
B5.5 Passat TDi, Euro model...
pdxa4 is offline   Reply With Quote
Old 11-16-2015, 11:41 AM   #6
ExcelerateRep
ExcelerateRep's Avatar
Drives: TDI
What all of these fellows are saying are corret. We service many of our customers who have stage 2+ GTi's and Golf R's. Oil every 5k miles, and cam follower every other oil change (10k miles)
Such an unfortunate thing happened to you. If there is anything you need please let me know. We have pumps on the shelf if you are planning to put an APR pump back in it.
Thanks,
Greg
ExcelerateRep is offline   Reply With Quote
Old 11-19-2015, 12:24 PM   #7
thedude4bides
thedude4bides's Avatar
Drives: '12 Golf R
Wow, you are lucky they are covering it.
Old 11-20-2015, 03:21 PM   #8
Antdez
Drives: 2012 Golf R
Thanks for the replies I actually gave you guys a call at excelerate to see about that pump. (I left a message). I was hoping someone could let me know hat I should do in the meantime. I got the car back and they put an OEM fuel pump on it so I have just been keeping it in Stock Mode on the GIAC tuner. It is running like molasses compared to how it was with the APR pump. Should I just keep it on stock mode or would it be fine to put it back into Pump Gas mode?
Old 11-21-2015, 09:45 AM   #9
thedude4bides
Drives: '12 Golf R
Even in stock mode, I would baby it or not drive it even until an upgraded pump is installed. The "stock" map probably isn't really stock at all. It's a tune designed to work with your modification that produces stock-like power/boost. If it's a giac tune then you should call them and try to talk to someone knowledgeable on the subject and they'll hopefully have a better handle on the risks.
Old 11-28-2015, 06:47 PM   #10
light-spigot!
Drives: 2012 Golf R
camshaft needs replaced with hardened camshaft (#06F.109.101B) for high pressure fuel pump bearing on the camlobe
light-spigot! is offline   Reply With Quote
