Kiev
My setup is Apr Stage II.2, APR carbonio stage II, APR full TBE.
2 days ago I took my car to install the APR FMIC It was working fine until today. It started surging and idle was erratic coming from work. Then check with VAG and throw these fault errors any idea? THANK YOU! :
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH06--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 71E3123D11C1
3 Faults Found:
000289 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 41118 km
Time Indication: 0
Date: 2019.14.07
Time: 06:28:50
Freeze Frame:
RPM: 3153 /min
Load: 15.7 %
Speed: 128.0 km/h
Temperature: 94.0°C
Temperature: 19.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 41123 km
Time Indication: 0
Date: 2019.14.07
Time: 06:33:34
Freeze Frame:
RPM: 1092 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 24.0°C
Voltage: 13.970 V
005445 - Throttle Valve Controller: Malfunction
P1545 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 30.0°C
Voltage: 12.065 V
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
Coding: 114B600CC9280000880E06E4931A00413008
VCID: 7DFB3E0D5D99
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 41118 km
Time Indication: 0
Date: 2019.14.07
Time: 06:28:51
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 51072
Count: 1
Count: 766
Count: 0
VCID: 71E3123D11C1
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 41118 km
Time Indication: 0
Date: 2019.14.07
Time: 06:28:50
Freeze Frame:
RPM: 3153 /min
Load: 15.7 %
Speed: 128.0 km/h
Temperature: 94.0°C
Temperature: 19.0°C
Voltage: 13.970 V
P0507 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 41123 km
Time Indication: 0
Date: 2019.14.07
Time: 06:33:34
Freeze Frame:
RPM: 1092 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 24.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 30.0°C
Voltage: 12.065 V
Revision: 00H45001
VCID: 7DFB3E0D5D99
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 41118 km
Time Indication: 0
Date: 2019.14.07
Time: 06:28:51
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 51072
Count: 1
Count: 766
Count: 0
