08.5-11 ESP Defeat
carsfeverguy
ImageUploadedByTapatalk1418778359.274469.jpgImageUploadedByTapatalk1418778372.243244.jpgImageUploadedByTapatalk1418778379.804573.jpgImageUploadedByTapatalk1418778387.462538.jpg
tire pressure monitor gets enabled....
ThatGTI
Here is a quick video on how to do the ESP defeat. I'm doing this on a 2010 manual GTI with the AM version. It should be the same process for 2010s and 2011s, but the AH isn't the same. I'm not responsible if anything occurs while you change anything on VCDS.
The Fixer
He told me pumps ending in AH and AJ have a different function. I can confirm this works on the 10 GTI.
ABS Brakes, coding, long coding helper, change byte 16 to 3C. Our DSG car had hill assist enabled, so I checked that back and it changed to 3D. So I hit 'DO IT!' and it worked. Previously showed B5 for that byte. I will also have to attend autox to see the difference.
The Fixer
I had a feeling it was a simple change, had no idea it would be this easy. He told me a colleague figured it out and they are testing other pumps. If people can post their year and pump version that works, I can update the first post.
carsfeverguy
Please have them look at the AH ones... I can be a test subject if they need it.
April 2010 mk6 manual gti
114B800C49290001880B01E4921A0041300800
engineered2win
I have a 2011 TDI with ABS module 1K0907379BC and it did not work. Bit 16 was originally B7. B7 changes to B3 when I uncheck the TPMS, but it will not accept the changes unless TPMS is enabled.
Edit1:
B7 = 10110111 = Hill Hold & TPMS enabled
B3 = 10110011 = Hill Hold Enabled, TPMS disabled
3C = 00111100 = ?
3D = 00111101 = Hill Hold enabled, TPMS enabled
39 = 00111001 = Hill Hold enabled, TPMS disabled
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B400C492300FF881102E492190042B70800
Shop #: WSC 12345 123 12345
VCID: 74C1F090D759B1817B3-8021
Edit2:
I changed byte 16 from B7 to 3D. It isn't a 2 stage TCS/ESP button; it changed the button to ESP disabled or ESP/TCS Active. I really have no use for disabling TCS, so atleast I have a functional button now. I got a rather strange ABS fault after flashing it to 3D:
02186 - Engine <-> ADR Interface
004 - No Signal/Communication - Intermittent
I can't find much info on ADR interface, but I cleared it. We shall see if it returns.
aw6141
I have a 2011 TDI with ABS module 1K0907379BC and it did not work. Bit 16 was originally B7. B7 changes to B3 when I uncheck the TPMS, but it will not accept the changes.
Mine has B7 also in the coding, did you just try changing it to 3c in the new long coding instead of changing it through the long coding helper? I will have to check if I still have hill assist.
This is my abs module information from my previous post
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492400FA880B06ED92220041B70800
Shop #: WSC 01357 011 00200
VCID: 78D131C3CB505BD8195
And the coding changes if you want to put that in the sticky.
My old coding byte 16
New Coding I put in long coding:
114B600C492400FA880B06ED922200413C0800
EDIT: I messed with it again, and I am using 3D now which keeps hill assist and the abs based TPMS. I think 39 will keep hill assist, but disable TPMS. I was doing it in a hurry, but you can probably mess with the settings and verify. My battery is weakening so I will probably wait until next week until I get the new battery before I mess with it some more. (it's cheaper at the dealer than the autoparts store so I set up an appointment lol)
kern417
zrickety are you still on your original control module? mine is bad and i'm wondering if picking a specific replacement will let me jump on this. i was originally looking to see if a 2012+ module could be swapped in to enable the esp defeat.
