08.5-11 ESP Defeat
The Fixer
Yes, the 09 is still on the original module ending in AD.
carsfeverguy
Some long codes from various people, I really think if we compile these we can maybe get somewhere. I invite you to help you fellow enthusiasts, by posting the version of your ABS and the long code. As well as the year. It would be interesting to know why an 09 can do it but to all 10s
AH
114B800C49290001880B01E4921A0041300800
114B600C492200FF881006E492190041300800
AJ
11424012092300FC880C02E5901A0041390800
113B200D092A00FB880D04E7901E0041350000
BG
114B600C492400FA880B06ED92220041B70800
BJ
113B200D092600FB880F04E5901B0041310000
323B601609230E024C1306EC901C7042350000
AM
114B600CC9290001881406E9932000413408
AE
113B400D492400FF881202E9921B0042B100
163B600D092300FF680D06E6901D0081B500
Pmanpop
This is preety cool. I have esp deleted through the steering angle coding so it's permanently off all the time. But this would be cool for those who want the option. Does xds still work with this?
corrado917
Good question!
carsfeverguy
Since the steering sensor is not disabled, XDS should work normally.
Question for you folks where the setting took.
For BYTE 16 what were the Binary codes before and after the setting took???
The binary number is a 8 number number made of 0 and 1.
I am curious to see if the binary code can give us a clue where this setting hides in the AH module.
Thank you in advance.
nafljhy
So I have a BG pump and I was able to do the code change! However, I can't tell if it's fully disabled or not..
I can checkk the binary codes for you in the AM.
EDIT: I should clarify that I don't have the two stage of just TCS then ESP.
When I do disable it, I get that ESP is disabled. However, when I turn it back on, I get "TCS/ESP is active". Before changing the code, it didn't say that when re-enabling ESP/TCS.
EDIT2: OK! so the code change DID work! I know cause as I was looking up the binary codes, I decided to switch back to my original coding, but no two stage disabling.
B6 = TCS Deactivated - TCS is Active
VS
3C = ESP Disabled - TCS/ESP is Active
nafljhy
Thank you
NP! I actually couldn't wait so I went ahead and got the binaries.
3C - 00111100
B6 - 10110110
B7 - 10110111
Another thing to note is that I have TPMS checked but Hillhold Assist Uninstalled. If I have Hillhold Assist installed the code goes from B6->B7
carsfeverguy
No man, I am actually hitting the hay, so I will try to continue tomorrow... Since B7 was your stock setting I want to look in all the other bytes, a binary that looks like your stock one... If that makes sense. Thinking of that, since this byte does take care of the hill hold and tpms, maybe it would be good to have the binary of the byte when both are disabled, yet stock...if that makes any sense.
nafljhy
Not a problem and yea, that makes sense. I've added the binary for B7 in my previous post.
aw6141
Binary of the following. I need to check it again, but I think 3D has hill hold and tpms enabled. 39 I can't recall, but if someone can verify for me since Im at work, if it had hillhold and tpms both disabled, both had ESP disabled with a button press.
3D - 00111101
39 - 00111001
The Fixer
On the 2010 mine said B5 before the change. I do have indirect TPMS and hill hold enabled using 3D.
