2010 VW GTI multiple Misfire
Jakesac51
My gti has 130k and is missing really bad at idle but it’s fine once I start driving it it’s got to be more than one cylinder Bc it sounds like it’s loping.
These are the codes I pulled:
P052A
P0300
P0055
C3064
C342D
Help please I need to fix it and don’t want to take it to the shop!
GolNat
When is the last time the plugs or coil packs were replaced?
Did you pull a plug to see what it looks like?
Stock or tuned?
GolNat
I replaced one coil pack about a month ago and it looked kinda bad and it’s totally stock
I'd replace all 4 along with brand new NGK spark plugs. Make sure you check the gap, they can be of from the factory even tho they come pre-gapped.
Jakesac51
Tried moving it today and it stalled and wouldn’t restart....pulled all the coil packs and two looked burnt up but I think it may be a fuel issue or something else bc I didn’t have problems until it got cold outside and I tried starting it
GolNat
When was the fuel filer last replaced?
Do you have OBD11 or VCDS?
vdubnick
why would you only replace 1 coilpack? have you changed plugs yet?
CleanAsFckMk6
CleanAsFckMk6
And any other question going through your head about what else cold possibly be neglected like that...What is All of it for $2000..
Jakesac51
I’m replacing the coil packs and plugs later today but I doubt that is it. All coil packs and plug just don’t go out at once after i drove it 1 hour and let it sit. If it’s not I’m going to check the fuel filter and pump. I’m going to check the intake manifold too because I heard there’s a lever that always breaks
vdubnick
yeah, the intake flap is super easy to check, im sure there are a few youtubes showing how.
but really, with 130k, it could be a shit ton of carbon build up... time to pull the intake and get out that toothbrush
vdubnick
