Hello, My abs engine light is on and Air bag error are showing up too.. Here is vag's log, Can anyone give me advise how to fix those?
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BG HW: 1K0 907 379 BG
Component and/or Version: ESP MK60EC1 H31 0106
Software Coding: 114B600C49240002881106E9921A0041B70800
Work Shop Code: WSC 01357 011 00200
VCID: 78A283B712D10ECB6BB-802C
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 12
Reset counter: 137
Mileage: 178468 km
Time Indication: 0
Date: 2033.14.04
Time: 19:08:02
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 69
Count: 49920
Count: 0
Count: 65289
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 137
Mileage: 178469 km
Time Indication: 0
Date: 2033.14.04
Time: 19:09:29
Freeze Frame:
Count: 16385
Count: 2
Count: 12800
Count: 16390
Count: 50432
Count: 65280
Count: 1276
Count: 4352
Address 15: Airbags Labels: 5K0-959-655.clb
Control Module Part Number: 5K0 959 655 B HW: 5K0 959 655 B
Component and/or Version: AirbagVW10G 021 0706
Software Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012 (VW36)
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392446B369DBD7C3545-806C
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Control Module Part Number: 1K0 909 144 M
Component and/or Version: EPS_ZFLS Kl. 74 3201
Software Coding:
VCID: 343A778742392AAB873-8060
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 12
Reset counter: 178
Mileage: 178480 km
Time Indication: 0
Date: 2020.07.30
Time: 20:21:41
Freeze Frame:
Voltage: 13.50 V
DU
Temperature: 43.0∞C
RPM: 870 /min
Speed: 22.0 km/h
Speed: 22.0 km/h
Count: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 12
Reset counter: 137
Mileage: 178468 km
Time Indication: 0
Date: 2033.14.04
Time: 19:08:02
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 69
Count: 49920
Count: 0
Count: 65289
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 137
Mileage: 178469 km
Time Indication: 0
Date: 2033.14.04
Time: 19:09:29
Freeze Frame:
Count: 16385
Count: 2
Count: 12800
Count: 16390
Count: 50432
Count: 65280
Count: 1276
Count: 4352
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 178
Mileage: 178469 km
Date: 2033.14.04
Time: 19:08:18
Software Coding:
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 178
Mileage: 178480 km
Time Indication: 0
Date: 2020.07.30
Time: 20:21:41
Freeze Frame:
Voltage: 13.50 V
DU
Temperature: 43.0∞C
RPM: 870 /min
Speed: 22.0 km/h
Speed: 22.0 km/h
Count: 0
