Roadrunner_GTI
I've had the car for a few years now but just now getting around to putting a thread together. This car used to be my daily driver, and now the car is more track focused, however the car still needed to be streetable
Modifications as of 12/2022:
Engine:
APR K04
Cobb AP w/ Stratified Protune -93 Oct
APR Cast Downpipe
AWE Catback
Unitronic Intercooler
Neuspeed turbo outlet pipe
Carbonio Stage 1 Intake
R8 Coil Packs
iAbed Rear Main Seal
Mk5 R32 Aux Radiator
Verus Hood Vents
Drivetrain:
Peloquin Limited Slip Differential
DIY RSR Clutch Kit
Spulen clutch bleeder block and stainless steel line
Diesel Geek Sigma 6 Shifter
BFI Stage 1 Engine / Trans Mounts
Neuspeed Dogbone Insert
Suspension / Chassis:
Racingline Springs
Koni Yellow Sport Dampers
Ground Control Camber Plates
Superpro ball joints
H&R 26mm / 24mm Sway bars
Superpro sway bar end links
Superpro Anti-Lift Kit
Subframe Collar Kit
Tyrolsport Hatch Brace
ECS Skidplate
Brakes:
Stoptech ST40 BBK
Stoptech stainless steel lines
G-LOC GS-1 Pads
Audi RS3 Brake Cooling ducts
Autotech wheel well vents
Motul RBF600 Fluid
Exterior:
Depo R LED Taillights
ECS Smoked Side Marker Lights
Gloss Black front and fear VW emblems
MK7 Performance Pack red GTI front and rear emblems
Interior / Diagnostics:
NewSouth Performance Boost Gauge & Vent Pod
NewSouth Performance Oil Pressure
Rennline Heel/Toe Extensions
Engine:
APR K04
APR Cast Downpipe
AWE Catback
R8 Coil Packs
Verus Hood Vents
Drivetrain:
DIY RSR Clutch Kit
Racingline Springs
Subframe Collar Kit
ECS Skidplate
Brakes:
Stoptech ST40 BBK
G-LOC GS-1 Pads
Motul RBF600 Fluid
Exterior:
