20k Service - Service Tech didn't rotate tires because they were all wearing evenly. Does this make sense or is this pure laziness?
Flippy
Location
Los Angeles, CA
A couple days ago I took my car in for it's 20k VW Care service and upon checking out I never spoke to the service department guy I was dealing with, I just grabbed my paperwork from the cashier and went home. It was few hours later that I noticed that the service tech noted that they didn't rotate the tires on the vehicle because the front and rear tires were both at 6/32 and were wearing evenly. Am I crazy, to think that they might be wearing evenly because they have been properly rotated in the past and now it's time to do so again or am I missing something here. Is this a valid reason not to rotate tires or am I dealing with a lazy ass service department?
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
If they are all even what does it matter? Do you rotate the tires when you’re taking possession of a new vehicle and driving off the lot with all tires evenly new?
dtfd
Location
Massachusetts
Car(s)
MK7.5 GTI
if the vehicle is new the tires would all the pretty unused so, no rotating wouldn't make any sense. 20k miles is roughly the half-life of a tire. That's about the time to rotate if you're already doing a service.
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
If I am putting on my track day tires and they’re all evenly worn, do I put them on, then take them all off again and rotate them before driving on to the track?
dtfd
Location
Massachusetts
Car(s)
MK7.5 GTI
do you live 20,000 miles away from the track? If you do, yea it's probably a good idea.
Otherwise if you live a reasonable distance away the difference in that drive is negligible. As negligible as the tire wear on a car being offloaded from a truck into a dealer lot.
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
Let me be clear with the scenario… Took off my street wheels and tires. My Track Tires are even. I Bolt them on, then Take them off immediately, rotate them, then torque the lug nuts to drive on to the track. Why would I do such a thing? Tires are even. Why bother….That’s what the tech concluded. You can call it lazy. I call it being efficient with his time.
RobertJG25
Location
Niagara Falls, ON
Car(s)
2019 VW Golf 1.4 TSI
Its possible that the tires were actually worn the same amount....for example if they both started at 10/32 lets say, then went to 8/32 (front) and 9/32 (rear) by your 10k interval and rotated, they would all be at 7/32 by 20k assuming they wore at the same rate prior to the first swap.
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
Another scenario… mid track weekend, I’ve worn the front tires on my GTI significantly more than the rear tires, so I swap them before the next sessions. I run a few more sessions and now I have even tire wear. Do I take off my evenly worn tires, rotate them, then drive more? No I don’t, because they’re evenly worn tires!
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
One more scenario….
You take off your wheels and tires (all evenly worn)…. You set them aside and wash them with soap and water to clean off the brake dust which has accumulated. Now your wheels are nice and clean and you can’t tell which pair went on in front previously because the brake dust accumulation has been cleaned off.
You have 4 shiny wheels with evenly worn tires. Where do you put each wheel/ tire on now, front or back?
krs
Location
Las Vegas, NV
Car(s)
MKVIIS R
One more scenario….
I put a metal punch stamp on the back surface that faces the hub, therefore I know where they go. I'd then refer to my notes to see which wheel came off which hub, and then rotate. 🤷‍♂️
SouthFL_Mk7.5
Location
South Florida
Car(s)
2019 GTI S
For heat cycle purposes? You probably have a psi log also per ambient/track temperatures. Lol!
