SunLu PLA
Bed Temp: 70C
Nozzle Temp: 210C (I tried 200C)
Speed: I have tried 50, 60 and 75 mm/sec didn’t seem to make a difference.
I can modify the G-Code to change fan speed and print speed at a certain layer correct? I have only tried to modify it for a filament change and it didn’t work.
Looking at it now, you should be able for support that overhang without supports. If your layer adhesion is good on lower layers flip the object vertically and go again.
Just a theory…. Your layer being laid only gets a partial contact patch with the layer below. When the extruded passed around it’s pulling the filament into open space. By flipping the part you’d be pulling that layer against the previous layer. See ASCII diagram:
——______ —>
______
(Auto formatting required use of dashes to locate the top line out)
Vs.
<— _______
______
Pulling the book off the shelf vs pulling the book onto the shelf, if you will.
