Tehred5pade
2012 vw cc with 150k miles. i replaced wheel speed sensors on all 4 corners, wheel bearing and hub assemblies on all 4, and replaced the pads and rotors on all 4. still having issues. ill leave in all the errors regardless. i tried clearing them and these came back. thanks in advance
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
============1==============
18255
Raw code: 474F
ECU: 02. Transmission control unit
Status: Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: P1847 Read data from the fault memory of the ABS control unit; Please read out the fault memory of the ABS control unit
============2==============
0290
Raw code: 0122
ECU: 03. ABS control unit
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
Volkswagen: Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
============3==============
0283
Raw code: 011B
Status: Pending fault present, Test is inhibited by other DTC, Validated and stored in non volatile memory
Volkswagen: Front Left Wheel Speed Sensor-G47; Front left speed sensor-G47
============4==============
3841
Raw code: 0F01
============5==============
3842
Raw code: 0F02
============6==============
53271
Raw code: D017
ECU: 01. Engine control unit
============7==============
2394
Raw code: 095A
ECU: 09. Onboard supply control unit
Status: Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
Volkswagen: Front Left Parking Lamp-M1; Front left parking light lamp-M1
============8==============
3551
Raw code: 0DDF
ECU: 15. SRS
Status: Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
============9==============
1176
Raw code: 0498
ECU: 25. Immobilizer
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: Key; key; Tank ventilation system, solenoid valve 2 for activated carbon-N115 signal too small
============10==============
2823
Raw code: 0B07
Volkswagen: ELV blocking conditions not met; Interlocking conditions for ELV not met
============11==============
66048
Raw code: 010200
ECU: 42. Driver door electronic equipment[Archive (inactive)]
Status: Confirmed
============12==============
1316
Raw code: 0524
ECU: 44. Power steering
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
Volkswagen: Brake control unit
============13==============
1316
Raw code: 0524
ECU: 53. Parking brake
============14==============
2635
Raw code: 0A4B
ECU: 56. Head unit (MMI) (VW TP2.0)
Volkswagen: The tuner is not turned on or not activated.; Tuner not activated or activated
============15==============
0872
Raw code: 0368
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: Subwoofer, rear left-R15; Woofer, rear left-R15; Camshaft position sensor => encoder G300 signal too high
DTC report
18255
Raw code: 474F
0290
Raw code: 0122
0283
Raw code: 011B
3841
Raw code: 0F01
3842
Raw code: 0F02
53271
Raw code: D017
2394
Raw code: 095A
3551
Raw code: 0DDF
ECU: 15. SRS
1176
Raw code: 0498
2823
Raw code: 0B07
66048
Raw code: 010200
Status: Confirmed
1316
Raw code: 0524
1316
Raw code: 0524
2635
Raw code: 0A4B
0872
Raw code: 0368
