torga
So I have a slow oil leak that I've only been semi-successful in tracing. It seems to be coming from somewhere in the front of the engine, as I see some oil hanging on the bottom of the A/C compressor as it comes down, as well as a section right above it. I don't think it could be the upper timing cover - like another user's recent thread - because the top of my head and the surrounding area around the cover are bone dry.
However, there's a part somewhat behind the alternator and to the right of the oil filter that looks like several 1/8" plates fastened together. I'm unsure what this part is, but there's a small amount of oil on top of it, and a bit underneath it, similar to the A/C compressor. I was unable to get a good shot of the bottom of this piece.
Attached are some of the photos I took.
First, is the bottom of the A/C compressor with oil hanging from it.
Second, is slightly above the compressor, which also has some oil hanging from it.
Third, is a clear shot of the part that looks like several plates.
Fourth, is a shot of the oil on top of this piece.
Fifth, is where the oil is pooling on my belly pan. Directly above this area is the accessory side of the engine.
This oil is getting blown back and coating the bottom of my oil pan as well as hanging from the Torx sockets on many of the oil pan screws.
Does anyone have any ideas on a potential source for this leak?
Thanks.
Thanks.
