ChrisAttebery
I went to Laguna Seca with NCRC again yesterday. It was a 103dB day so there were a lot of fast cars. I wanted to run in Point By but was told that I should stick to Solo for this day since there wouldn't be a driving school and everyone in Solo was supposed to have previous track experience. There were 3-4 drivers in the class that clearly should have been with an instructor. I was passing some of them 2-3 times in a 20 minute session. Some of them were fine but one guy in a Mini was braking hard and pointing people by in the middle of corners. Another guy in an Elise was braking really early, in mid corner, not following the line and not pointing people by. He was really pissing me off.
Anyway the car felt really stable even under hard braking, turned in well and felt balanced mid corner. The RS4s were nice. I set them to 37 PSI hot and had to remove some air after each session. They are a little squirmy, but they had better traction than the Direzza IIs that I had before. The tires had even temps across their faces. The fronts were in the upper 130's and the rears were in the upper 110's to lower 120's. I set both sway bars (H&R 26mm F, H&R 24mm R) to stiff and left them alone.
Right when I got home the TPMS light came on. The tires must have finally cooled off enough on the way home to lower the pressure. I'll check the cold pressure today to see where I wound up.
Yes, that was a Viper ACR passing me at the beginning of the front straight. He was by far the fastest guy in my group.
