APR Direct Replacement Brake Upgrades!
Arin@APR
GOLFMK7 Official Sponsor
APR Direct Replacement Brake Discs and Pads
APR Direct Replacement Brake Discs are a plug-and-play upgrade for your factory brakes. They provide reduced brake fade, improved brake consistency, and excellent modulation, especially during repeated consecutive braking applications or spirited driving. The rotors have improved resistance to distortion, warping, and cracking at high temperatures. They pair perfectly with the APR Direct Replacement Advanced Street Pads, and provide a no-compromise solution for spirited daily driving.
Features and Benefits (Discs)
  • Direct replacement front and rear discs
  • Various factory sized vented and solid discs with slotted faces
  • Reduced brake fade and improved brake consistency
  • Improved initial braking response or bite
  • Improved brake modulation, especially during emergency stops
  • Improved resistance to rotor distortion, warping, and cracking at high temps
  • Slot pattern specifically designed to evenly distribute heat across the rotor surface
  • Slot pattern operates smoothly and quietly over a wide application range
  • Cast in Europe from a proprietary high carbon cast-iron alloy
  • Machined to tolerances up to three times tighter than the industry norm
  • Maximum Temperature Recording (MTR) system
  • Proprietary black, anti-contamination finish ensures no oils are transferred to the pads
  • Suitable for normal daily driving and spirited driving
Features and Benefits (Pads)
  • Direct replacement front and rear brake pads
  • High friction co-efficient
  • Brake torque curves engineered not to overwhelm street-legal tires
  • Max operating temperature approaching race pad levels
  • Low disc wear
  • Low levels of heat transmission to the calipers, seals and brake fluid
  • Don’t need to be warmed up before they are effective
Our application guide is extensive across many VW and Audi makes and models from roughly 2005+. This covers nearly every VW (except touareg), and all of the smaller Audi's such as the A3/Q3/TT and their higher models.
Get The Details and Find your Vehicle:
Shop Direct Replacement Brake Discs
Shop Direct Replacement Brake Pads
Not Enough? Learn about our Big Brake Program:
Shop Big Brakes
vdubnick
are the pads better than OE spec, as far as the assembly process? (pad to plate, coating, etc.)
tdream1
I wish I knew about these prior to having your BBK kit installed. I would have replaced my rears at the same time and be able to bed them all at the same time.
Arin@APR
very much interested👍. Dust/noise level for the pads?
Dust I can't say I've seen enough back to back compared to stock to comment, though I don't recall anything excessive, or overtly low dust.
As for noise, these are not like a race pad. They are good for daily driving with low NVH.
Joe_Mama
Awesome! These brakes look swank as hell. Love that you guys are still developing for this platform. keep em comin
Tyler12108
These look nice I will probably try these out soon, currently running stoptech slotted rotors with their street pads and I'd be interested to compare
vdubnick
is the rotor mass same as stock?
