ASTRID - Track Rat Build
zef
thanks guys! hoping I wont rub with the 5mm...I had to get special lugs because the motgeis come with allen lugs since a regular lug you cant get a socket on because the holes are very small...with the 5mm spacer I had to track down longer ones
zef
Ever since going KO4 and competing with the car I always noticed the bottom of the DSG looked "wet" with DSG fluid. I had the rear main seal replaced with the iabed part so I was fairly confident that wasn't the case. I even replaced the DSG pan with a new gasket, yet the issue remained.
Finally, I found out that the DSG trans actually has a breather port on top next to the starter. Instead of just accepting this as an asinine design, I looked to a possible solution. Because the port is very small, it would be difficult to come up with a catch can solution because the port would have to be tapped which wouldn't be possible with the trans still on the car.
The solution? A $30 part from Volkswagen. The MK7R comes with a "breather box" that plugs into the port that clips onto the stock battery box. Figured it was worth a try, and turns out it literally plugs right in on the MK6 GTI! Because I have the ECS tuning battery box I was able to secure it to my tyrolsport master cylinder bracket. I'll just have to empty it every once in awhile.
https://www.shopdap.com/02e-301-472-e.html
Thanks to Dan @ Excelerate Performance for the suggestion!
zef
Dropped the car off at ACI Dynamix today for a full front nose clear bra and 9H Ceramic coating...exactly 1 week away until my first track day of the year.
Driving around on the new suspension and....wow....whereas the feedback through the steering wheel was always numb, the camber plates/coils have opened up a whole new line of communication and it's incredible. On full soft it's actually quite nice, not harsh at all.
zef
Great build, love the color! However i was curious as to why did you take off passat spindles?
Great question. Unfortunately, my Brembo BBK bolts to the outside of the spindle. The "ears" of the Passat spindles are thicker, so the brackets are pushed too far inside the wheel well for the calipers to bolt up. This wasn't an issue with my prior brake setup because they bolted to the inside of the spindle, and all I had to do was run longer caliper bolts.
Both with the Passat spindle and with the OE steel spindle, my superpro ball joints had no problem clearing the brembo rotors (355x32); though the clearance is pretty tight. I'll have to DEI foil wrap the boots just to be safe.
GoLfUnV
Did you think about machining the "ears," or was the "offset" too big?
zef
It absolutely crossed my mind, but this was discovered earlier this week with less than a week to go before my track day at Thompson. Due to time constraints I decided it was better to go back to steel.
It was off by a fairly significant amount however, so I am not sure that would be safe. What I would end up having to do most likely is building custom brackets.
If the steel spindles do end up failing then I'll either have to change my brake setup again or figure out at way to make it work.
DEI wrapping the ball joints is good practice anyways.
Agreed, I'm going to wrap the ABS sensors too just to be safe.
GoLfUnV
Thanks! glad i found your build thread... I have set of boxster brembo calipers, waiting on rebuild, before i install on my mk5. I was contemplating passat spindles, for un-sprung weight reduction, but looks like i may have to do some more research.
jay745
track sl00t
Zef did you by chance weigh the spindles to see what the weight savings actually is? I've considered doing that for years (last part of the unsprung weight items that I haven't converted over) but the fitment with brakes has kept me away.
zef
Those I am pretty sure bolt to the inside of the spindle so you should be okay, but definitely double check.
I didn't, but someone else did: https://www.golfmk6.com/forums/showthread.php?t=47369&page=2
About ~3lb difference per spindle.
zef
Today was a final big push to get the car ready for tomorrow.
- New APR Intake filter
- Cleaned MAF
- Changed oil with fresh 300v
- Wrapped ABS sensors/ball joints in DEI foil (clearance between superpro ball joint and rotor is literally 1mm, maybe 2)
- Test fitted 8mm APR spacers with extended tuner lug bolts (35mm bolts) on front to ensure proper clearance
- Fresh coat of glass sealant in anticipation of the crummy weather
- And finally fully packed the car with everything (tools and all)
Here's what the fronts look like with 8mm spacers. Originally 5mm cleared the shock, but only barely. It was decided 10mm would be too much, so I went with 8mm, and it's totally spot on.
zef
First track day was a huge success. It was pouring ass rain for the first 2 sessions which made for lots of fun. It dried up for the last 2 sessions and I got some quality runs in. Oil temps got pretty warm (~265F), but coolant temps seemed pretty stable. "brake fluid-owners manual" came on a few times pulling into the pits, but I am assuming that's my car complaining about hot brake fluid.
Oh, and I also cracked my downpipe pretty good (again!), so I have an APR downpipe going in to replace my Cobb. Done with that company forever.
Photos/Video coming soon...
DASVDUB
Yeah I’ve heard complaints numerous times on Cobb exhausts. Subi platform has issues with them too.
Did you check your reservoir when that popped up? What fluid you running?
zef
Reservoir was full, level didn't budge.
3 day old Castrol SRF fluid.
theclutch
Where? What track? Per chance, did you log EGT?
APRMK6GTi
new APR downpipe is pretty well constructed, my 42dd downpipe cracked also, hopefully APR one will last
zef
This was at Thompson. I didn't log EGT, but if I had to guess it was pretty damn hot (1800F+). To be fair this was the re-welded downpipe I've had for over a year so I knew I was on somewhat borrowed time.
I have the old style downpipe, but I've heard good things.
theclutch
I should have joined you! That's not too far away from me.
