Great question. Unfortunately, my Brembo BBK bolts to the outside of the spindle. The "ears" of the Passat spindles are thicker, so the brackets are pushed too far inside the wheel well for the calipers to bolt up. This wasn't an issue with my prior brake setup because they bolted to the inside of the spindle, and all I had to do was run longer caliper bolts.
Both with the Passat spindle and with the OE steel spindle, my superpro ball joints had no problem clearing the brembo rotors (355x32); though the clearance is pretty tight. I'll have to DEI foil wrap the boots just to be safe.
Did you think about machining the "ears," or was the "offset" too big?
DEI wrapping the ball joints is good practice anyways.
Thanks! glad i found your build thread... I have set of boxster brembo calipers, waiting on rebuild, before i install on my mk5. I was contemplating passat spindles, for un-sprung weight reduction, but looks like i may have to do some more research.
Zef did you by chance weigh the spindles to see what the weight savings actually is? I've considered doing that for years (last part of the unsprung weight items that I haven't converted over) but the fitment with brakes has kept me away.
First track day was a huge success. It was pouring ass rain for the first 2 sessions which made for lots of fun. It dried up for the last 2 sessions and I got some quality runs in. Oil temps got pretty warm (~265F), but coolant temps seemed pretty stable. "brake fluid-owners manual" came on a few times pulling into the pits, but I am assuming that's my car complaining about hot brake fluid.
Oh, and I also cracked my downpipe pretty good (again!), so I have an APR downpipe going in to replace my Cobb. Done with that company forever.
Photos/Video coming soon...
Yeah I’ve heard complaints numerous times on Cobb exhausts. Subi platform has issues with them too.
Did you check your reservoir when that popped up? What fluid you running?
Where? What track? Per chance, did you log EGT?
new APR downpipe is pretty well constructed, my 42dd downpipe cracked also, hopefully APR one will last
This was at Thompson. I didn't log EGT, but if I had to guess it was pretty damn hot (1800F+). To be fair this was the re-welded downpipe I've had for over a year so I knew I was on somewhat borrowed time.
I have the old style downpipe, but I've heard good things.
I should have joined you! That's not too far away from me.
