Barische's Car Build
barische
Also picked up 2 - used w/ 90% tread RE-11 (235/45/17)..
So should i put the re11 or re070 on front.. Keep in mind the re070 are 225 but tend to run larger.
I was thinking of using the re11 on front, i think the front staggered setup will work better i gotta go home n measure the contact patch width.
barische
installed H&R sport springs with Bilstein b8 ride is much more tolerable in these horrible jersey roads.
got an alignment today
front toe 0
camber -1.1 each side
rear toe in 0.02 each side
rear camber -1.8
gti330ex1
That wheel/tire combo looks real nice. And i agree with the black blending all in and looking like a >17" wheel. I wish i went this route instead of purchasing a new set of A/S michelins last year. I recently picked up a used set of oem audi 16" wheels w almost brand new star specs Z1s for $250. I was wondering what PSI are you running w your Z1s? Daily vs autox/track?
barische
Thanks
Daily 38-40psi
Auto-x and canyons - usually lower to about 35-38 psi hot
So maybe start at 33psi cold see where end up at at the end of 1st n 2nd session.
May need to run higher psi to prevent rolling over. Are u lowered whats ur suspension mods.
My tires r done btw so about to throw on those bridgestones
gti330ex1
Thanks
Daily 38-40psi
Cool, thanks. Suspension is stock. Because it's a 16" wheel, tire is 225/50, so maybe 35 or so should be a good starting point. That's interesting that you run a higher pressure for DD.
Props on the route you took with your car, and btw.. that side pic above is really sick/mean!
