Boost gauge
svickstc
no boost tap needed for p3 gauge, and the awe you need to purchase the boost tap seperately from the kit.
Newsouth is also another good option when comparing to AWE, or even Podi...
P3 uses OBD2 port for connection...
CFG9000
The P3 supports both digital and analog boost readings. You can use digital out of the box through the OBDII port, but using a boost tap would give you the more accurate analog reading.
svickstc
^^^Thats def a hot debate topic and usually the other way around, digital vs. mechanical is a debate that im not wanting to get into....
just throwing it out there
TAG12GTI
Take a minute to learn about the P3. The digital values are not true pressures in the intake track. Instead the P3 uses OBDII readings to interpolate the "boost." The analog, or mechanical, feature on the P3 uses a boost tap to give an actual reading from the intake.
I think you might be thinking of electric vs. mechanical for the boost gauge which allows for some "smoothing" with the electric though faster responses with the mechanical.
