Boxster brakes on gti
webbry4
Anybody know any brackets for the boxster brake setups other than apikol that are cheaper they are asking way to much for just a simple bracket
webbry4
This is not cheaper than the Boxster setup that OP wants.
To OP, no I dont think there is any out there
Ya i wish i could afford that kit it would be much easier but im looking for on a budget because apikol is charging wayyyyy too much for a simple piece of metal
BoostedVW11
^ something to think about though. ST BBK Includes everything neeed out of the box, lines, rotors, pads (all costs to factor in)
goodluck op
Roctre
Im in the process of putting the kit together and no one else makes them anymore. If you haven't bought anything yet you could go to the 17z cayenne setup for almost the same price because it doesn't require the bracket which makes the cost almost even.
theunholy
I wouldn't recommend the 17z brakes here. I've been there done that if you only care about looks then its ok. the braking power is not bad. Its just the pedal feels too soft. However, if you are Manual then it might actually help you to hoe and toe.
Roctre
Yea hearing about it making the pedal soft is what made me not go that path.
Sanderzzz
So this build would be boxster 17z brembos, this bracket, and pads?
Roctre
The 17z is from a cayenne/touareg. The boxster caliper is just has a normal part number but you need calipers from a 986 boxster. You need the calipers/bracket/SS lines with different fitting on the end akipol sells the lines with fittings you need/pads. Just a heads up the lines they use are stoptechs lines they just give you the banjo bolts and washers if i knew that i could of gotten the lines and bolts for about $40 cheaper.
Sanderzzz
Front or rear brakes from a 986?
bart2278
Are we talking about the 17z's or the boxster brakes here? I have the boxster fronts and they don't make the pedal feel soft, and the stopping power is great.
