We did it boyz. All mounts installed. Walk kit as well. 31.6k miles. Feels so good. Yeah there are more vibrations at idle.
A/c at idle sucks too. But it should go down over time. The first 30 miles have been a blast.
Update Edit: 100 miles down on these mounts.
Take off vibrations are pretty strong. To explain the intensity, you can watch the turn signal stalk shake as you are engaging the clutch. However, the vibration seems pretty exclusive to like 900-1200 rpm. Outside of that range, you would not know I have uprated mounts.
Now outside of vibrations, the engine idle noises are amplified. You can hear the ticking and chugga chugga noises, especially if your windows are up.
A/c amplifies vibes and due to added engine load, also amplifies engine sounds.
Basically you will only notice this combo at 900-1200 rpm and sitting at a red light. Shifts are butter smooth for me now.
