NewGuy1
Not following you. The diaphram is effectively the PCV and replacing the PCV will fix any issue caused by the PCV. If you're talking about another issue causing the PCV to not work properly that is not a PCV issue. That is a PCV symptom. Example, PCV not operating properly because of a vacuum leak. That is not a PCV issue that is a vacuum issue where the symptom is a PCV not functioning correctly. In the case of oil cosumption it would likey be an issue with the PCV diaphram itself as they ofter tear and oil consumption would definitely be a problem at that point as the PCV would not close at idle (max vacuum) and you'd be sucking in crankcase vapor like crazy. Also a diaphram failure would cause you to suck copious amounts of oil durring any spirited driving. It is possible that there is a slight vacuum leak causing the PCV to not fully close but with still enough vacuum to suck oil. In this case however there would likely be a code thrown whereas a torn diaphram would not throw any codes until a sensor got oily from it or something. If there was an issue not allowing the PCV to open at all then you would likely start blowing seals as the crankcase vapor has nowhere to go. Then you would also start losing oil as well but it would be showing up on your garage floor.
Not saying replacing the PCV will fix the issue but for $15 it's a start and given the issue the diaphragm is a strong candidate for the culprit.
Chill my dude.
The PCV (the unit itself as a whole) fails in a variety of ways.
https://www.youtube.com/watch?v=hQEciqR1ST8
A diaphragm only replaces one potentially problematic part.
Not saying its not a good attempt to fix for $15 buck, or that your wrong, just that its not a one all solution to failed PCV (again the unit as a whole).
With oil consumption being the main issue I agree that its likely the diaphragm but if he has an older PCV fixing that one part does not make the entire unit up to snuff and could just result in failing again.
