g-magoo
nope it’s getting burned up somewhere, i haven’t pulled plugs, you mean spark plugs correct? also what would i be looking for with those
also yes there is smoke from the exhaust everytime i barely even rev it a lot comes out
Yeah, spark plugs. You're going to be checking for residue/deposits or even a shiny black coating. Google image search: oil fouled spark plug.
Personally though, I wouldn't go solely off of the spark plugs. I'd do a compression test or have one done. Low compression #s on any or all cylinders would more than likely mean the rings are letting oil into the combustion chamber(s). If compression is good and solid across the 4 cylinders, then the oil is coming from somewhere else; possibly valve stem seal(s) or maybe even the turbo is leaking.
