Calling All Tuned MK6's how many miles on it?
leiito1
2010 Mk6 here. Don't remember when I went APR stage 1 and 2, but K04 at around 40K. Now at 109k and still holding up. Texas heat has really done a number on the interior though. Plastics around the center console and around door handles have melted and cracked and the headliner is off now for its second replacement..
Replaced clutch with the RSR kit at 98k and added the iAbed RMS at 103k.
Finally did the Timing, new water pump and carbon cleaning at 107k... 4 years ago.
Have only driven it 2k since then and needs new rear bearings. Wish I had more time for her.
Still looking pretty well conserved from the exterior though!
Cal2000
Stage 2 ECU @ ~65,000 Kms (~40k Miles)
DSG Tuned @ ~90,000 Kms (~55k Miles)
K04 @ ~145,000 Kms (~90k Miles)
Currently: ~185,000 Kms (~115k Miles)
2012 GTI DSG, all major components original but lots of preventative maintenance.
Would you be able to share what you have done for preventative maintenance? Thanks.
Knotical
145k here tuned since 90k or so, now running a K04. Still on the factory water pump and intake manifold.
davisharr
Lots, Oil changes every 8,000 Kms, DSG Services every 30k, Coolant and brake fluid flush every 2-3 years, 2 Intake manifolds, 3 Water pumps, carbon cleaning, timing chains and tensioners, a shit ton of plugs and coil packs. It's a steady stream of maintenance to keep it running nice, but nothing major has ever failed so its' been worth it so far!
GTiMKVI
Hey All,
Now that all our MK6's are at least 10 years old. I'm curious how many miles you guys/gals are up to? I've got a standard KO4 built GTI with 140k miles on it. So I am wondering what other folks are reaching for mileage on their engine, especially tuned.. Who's got the highest here?
Is this thing a ticking time bomb or am I good for 200k.. Obviously a lot of variables at play. Just trying to get an idea..
2011 GTi that I tuned in 2014 through APR. Just an ECU tune, but I have 98k miles and the car just started slipping. Happened 3 times on the highway in the past 4 months. Car went to neutral and I had to stop and restart for it to reset.
Code indicates bad clutch pack, but ever since I took off the tune a couple of weeks ago, the car hasn’t acted up.
Planning on replacing the clutch pack, but want to see if the code appears again now that it’s back into stock mode.
BadAssBass
2011. 113k. APR Stage 2 @ 30K.
Original tensioner.
supreme_gti
Original tensioner.
nice pics, check the chains, and replace tensioner.... I rather play the lottery and gamble with set of 7/6 numbers than timing/engine related gambles.... my two cents. Otherwise the car is CLEAN!
Tuning the car also adds more wear and tear.... applies to any car actually
jedred1
jedred1
I'm at 120,000 mi. now. I,ve had the timing belt done around 105,000 mi. I went stage APR stg. 1 at around 15,000 mi and stage 2 about 30,000 mi. She pulls even better now then at 40,000 mi.
I'm going to switch out the shocks struts from stock to Bilstein 8's in July. (I have drive gear springs). I'm hoping for about 200,000 mi.
boomerMK6
133k here and installed the K04 recently at 129k along with front mount intercooler, traction concepts LSD upgrade, all mounts. and new clutch flywheel. Pro tuned with Stratified and the car runs very strong. I feel it will run as good as you treat it, but I have replaced the manifold, HPFP, injectors, water pump, brakes, coils/plugs and above since purchasing the car, so it does take some $ to keep it going. Chains were done by the previous owner and I do all the work myself (saves labor costs). I feel proper maintenance is the key and will run well to 180k+
