Can someone please help me identify this clunking sound? (Driver's side front suspension)
BosnianBreakfast
If the road is not as smooth as glass, it is constantly clunking. I replaced the front end links but the sound is still there. I have a thicker aftermarket front sway bar, could that be it? The sound didn't start till recently and I've had the sway bar for a while.
Edit: It seems like a strut mount/bearing issue. But I'm using Ground Control camber plates, which I believe replace the original. The sound was present before (and obviously after) the new camber plates. Is there another strut part I should try replacing?
