Catalytic converter malfunction light on and can smell something, 2011 GTI That I just purchased does Catalytic converter,need replaceing,is it safe 2 drive
If you have a catalyst efficiency code then it will most likely be drivable, worst case the cat material can cause a misfire if it becomes dislodged from the pipe. Will obviously give a different fault code in that case.
