coding for led lights (ed's)
phd-12v
for front fog as drl along with LED----
BYTE 18 - is 20
BYTE 14 - is 0B (check bit 1, bit 3)
BYTE 15 - is C4 (check bit 6, bit 7)
BYTE 24 - is E4 (check bit 7)
BYTE 27 - is 24 (check bit 2)
this is the following
LED DRL and FOG light DRL at the same time
to have JUST LED DRL:
same as above with this one exception:
BYTE 14 - is 09 (check bit 3)
6D180A1A90272AC480080081600005C441010086434D8D60648020200000
above is when i had a new module installed, DO NOT CUT AND PASTE THE WHOLE CODE INTO YOUR VEHICLE. YOU WILL F*%K IT UP. YOU HAVE BEEN WARNED!!!!!!!
It is nothing more than an idea of the stock coding
IF YOU CHANGED BYTE 18 at some point, switch it to 20 then back to 00, then recode as necessary.
phd-12v
Tuesday,28,February,2012,19:28:57:10361
VCDS Version: Release 11.11.1
Data version: 20111209
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72
77
VIN: WVWHD7AJXAW425165
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H23--- Serial number:
Coding: 040301081C070160
Shop #: WSC 01357 011 00200
VCID: 70C1046663B8339
No fault code found.
Readiness: 1110 1101
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2113
Revision: 51112 Serial number: 00001004160221
Coding: 0000020
VCID: 140968F63760AF9
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492400FF880C06EA921E0041310800
VCID: 7AD5264EF5C4799
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
VCID: 75CF3572D4DA161
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0574
Revision: 00103 AF
Coding: 6D180A1A90252AC480080081600009C441012000434D8D60E48020240000
Shop #: WSC 40644 444 10146
VCID: 354FF5729C5A561
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 06051 23 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R0091HU
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957F942B842B21
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--000557SQ00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME32493153ZZZN
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME480B3353ZZZV
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME0234574EZZZU
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME0C22572CZZZY
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME030C0822ZZZ3
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME700C0922ZZZ9
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76CD327E01DC1D9
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 050510F2004359
Coding: ED807F07001612000002
VCID: 69F769024062C21
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R8XG806
Coding: 0000002
VCID: FEDDAA5EA9ECD59
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF5960E0D64499
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7668050009
Coding: 010000
VCID: 266D223E51FC2D9
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2139
Coding: 0001204
VCID: 334BCB6A522E481
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147C162A8327A1
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2113
Coding: 0001204
VCID: 3245CE6EAD34419
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K1139316
Coding: 0100040001
VCID: 61E7712278528A1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3449C87657204F9
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
Shop #: WSC 40644 444 101465
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
VCID: 354FF5725C5A561
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07770981
Coding: 412100
VCID: 2A75D60E45E4099
End ---------------------------------------------------------------------
THIS IS A COMPLETE AUTO SCAN AFTER THE CODING FOR LED DRL ONLY
phd-12v
please also see no faults in the network. so it is really a simple thing to do.
IF YOU SHUT OFF YOUR DRL ALREADY, turn them back on before coding the above.
Also note that the side markers are lit brighter during DRL than with the parking lights on.
IF YOU HAVE A EURO SWITCH with the parking light position, please know that the parking light position turns off the LED's now, however the rest of the parking circuits come on as normal.
Nimche
Thanks very much. I will work on this examples.
GOT IT!
xHeartcoreboyx
IceCream GTI
Good stuff!
I want the LED DRLs soo bad...but i also want to be able to do this VV
darth_furious
did you get it coded that quick???
BYTE 18 - is 20
This worked for me! I had byte 18,15,24, and 27, but everytime the "check DRL" notice came up and it never worked. Once I set byte 14 (check bit 3) to select bixenon with shutters, it worked. However, my highbeams now don't work.
Hmmm...DRLs or Highbeams? I personally am sticking with DRLs but the choice is yours.
phd-12v
that is my long code i am running currently
simply add fog as DRL and it will look like the above, i did it like 3 times last night just to be sure.
phd-12v
BYTE 18 - is 20
there has got to be something different, as my high beams work fine. hmmmmm check my long coding against yours and see where the difference is
Nimche
no juice yet. I got all sort of error because I have R tails. Maybe I try again when I have time with different settings.
phd-12v
that is where mine is different.........i dont have led tails.....i thought that might change things due to byte 18
what is byte 18 coded to right now in yours?
Nimche
byte 18 == 15
I had it as F1 or 1F but that didn't work and searched till I found 15. I could wish for a better wiring with these lights but I can't complain much,
darth_furious
I'll post my long code if I get a chance later tonight. Also, I have a golf variant (2010 JSW) and don't have fogs. Still really happy!
