Hi, and please forgive if this is not right on topic, but I'm trying to get some info on the schematic/function for the 'E229' (I think?) emergency flasher switch on the Mk6 Golf. I have a 2013 TDi and I've put a GPS mount and mini power supply 5VDC o/p socket exactly where the Emergency Flasher switch was, just because the location was spot-on, thinking I could simply add a tiny Momentary Pushbutton and an LED to sub in for the switch, just below it. Problem is, looking at the 4 pins on the switch, I can find zero difference in continuity between any 2 pins when the OEM PB is depressed. I'd guessed that there was a contact closure on a line to the ECU or via CAN bus controller or such, but I can find zero info anywhere! Anyone have an idea what's going on in that switch? I will simply pull it apart if I get desperate, but the info would surely help before that.
