Control Module in Instrument Cluster Malfunction, looking for ideas
Pennypacker83
Hello all,
First time post. I have a 2011 GTI that has ECU/TCU tunes from APR with full bolt-ons currently sitting at 121k-ish miles and since the winter started this year has been intermittently displaying multiple solid warning lights for virtually every system in the car (Brakes, Engine, tire pressure, fuel, etc...), but only when the outside temp is cold! This phenomenon resolves as soon as the outside temp warms up. With VCDS scan I see mainly J285 - Control Module in Instrument Cluster communication error (see log below). I feel this is solely a electronic communication issue as the car typically starts and runs normally. However, recently the engine starts up and dies within 2-3 seconds! In this state VCDS can-bus will not function with OBDII port. Any ideas would be much appreciated!
VCDS log:
Thursday,23,December,2021,12:04:25:55582
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHV7AJ3BW258579 Mileage: 197790km-122901miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AS HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 31890 001 1048576
VCID: 77D3005806145A3170-8022
VINID: 9E69D898745A0D29C214814724A35C016F
1 Fault Found:
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 197795 km
Time Indication: 0
Date: 2021.12.22
Time: 22:57:23
Freeze Frame:
RPM: 759 /min
Load: 4.3 %
Speed: 0.0 km/h
Temperature: 102.0°C
Temperature: 21.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 1110 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2724
Revision: 05351112 Serial number: 00001102170582
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 191726E0D040AC41A6-804C
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C49270002881006EB92220041B70800
VCID: 78D10364CB0A554979-802C
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 197786 km
Time Indication: 0
Date: 2021.12.22
Time: 22:34:04
Freeze Frame:
Count: 16384
Count: 12
Count: 12800
Count: 8208
Count: 50176
Count: 1
Count: 0
Count: 12800
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 178
Mileage: 197786 km
Time Indication: 0
Freeze Frame:
Count: 16384
Count: 12
Count: 12800
Count: 16390
Count: 50432
Count: 0
Count: 255
Count: 8448
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AC HW: 7N0 907 426 AC
Component: AC Manuell H18 0303
Revision: 00013001
Coding: 0000001002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75CF0A50D418282162-8020
4 Faults Found:
9477141 - Position Sensor for Air Distribution Flap Motor
B109C 15 [008] - Open or Short to Plus
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 15
Reset counter: 170
Mileage: 196228 km
Date: 2021.11.16
Time: 08:51:55
9474577 - Motor for Recirculation Flap
B1092 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 196577 km
Date: 2021.11.24
Time: 20:32:22
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 178
Mileage: 197786 km
Date: 2021.12.22
Time: 22:34:05
9672723 - Heated Seat; Front Left
B1398 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 178
Mileage: 196686 km
Date: 2021.11.27
Time: 20:38:35
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 L HW: 1K0 937 086 L
Component: BCM PQ35 M 104 0615
Revision: 00104 AE
Coding: 6D180A3A90272AC4008800817000054442010086530D8D60648020200040
VCID: 3957C660B0808C4146-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 16021 26 0512
Coding: 009795
2 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 7
Reset counter: 173
Mileage: 197600 km
Time Indication: 0
Date: 2021.12.18
Time: 20:47:32
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 178
Mileage: 197786 km
Time Indication: 0
Date: 2021.12.22
Time: 22:34:05
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
ON
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01Z1A7
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3957C660B8808C4146-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005F7EJ00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4D76605CZZZ3
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME1135155DZZZS
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME46400438ZZZK
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME4E520725ZZZV
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME791F4D26ZZZX
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME06254D26ZZZF
1 Fault Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 178
Mileage: 197786 km
Date: 2021.12.22
Time: 22:34:05
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KC1000OI
Coding: 1892140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76CD0D5CC91E23396B-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Serial number: 0010144
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 270D01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 354FCA5094986821A2-8060
1 Fault Found:
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 178
Mileage: 197786 km
Date: 2021.12.22
Time: 22:33:48
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 070311F1002201
Coding: 350002
VCID: 3041FB4463FA4D09F1-8064
2 Faults Found:
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 196632 km
Time Indication: 0
Date: 2021.11.26
Time: 07:55:50
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 161
Mileage: 197472 km
Time Indication: 0
Date: 2021.12.15
Time: 10:47:53
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RCAE006
Coding: 0000002
VCID: 7EDD157C292E6B7933-802A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 178
Mileage: 197786 km
Time Indication: 0
Date: 2021.12.22
Time: 22:34:05
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669520352
Coding: 010000
VCID: 287113245B2A05C929-807C
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 178
Mileage: 196205 km
Time Indication: 0
Date: 2021.11.15
Time: 10:38:46
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3147FE40A8F04401FE-8064
1 Fault Found:
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3449F75457E2712995-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 178
Mileage: 197786 km
Time Indication: 0
Date: 2021.12.22
Time: 22:35:36
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 19.0°C
RPM: 986 /min
Speed: 8.0 km/h
Speed: 8.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 3245F14CADF67F1987-8066
1 Fault Found:
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H16 0044
Revision: -----28S Serial number: VWZ4Z7L1106594
Coding: 0100040004
VCID: 61E74E007890B4812E-8034
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 105
Mileage: 190495 km
Time Indication: 0
Date: 2021.06.17
Time: 14:09:24
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 178
Mileage: 0 km
Time Indication: 0
Date: 2021.12.22
Time: 22:34:04
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669510225
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 62E5410C7596AF9937-8036
1 Fault Found:
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 177
Mileage: 197786 km
Date: 2021.12.22
Time: 22:34:04
drval85
Goddamn that’s a lot of codes. I’d clear them all, go for a ride and see what returns. I know multiple codes across various modules can also be caused by a dying battery, so check that.
LeviathanGTI
Seems to be a rare issue. I've only found a few references to it across all of the forums. When its below 30 degrees here I get the u0155 code and the car starts and immediately shuts down. I've had to resort to putting a small space heater on the floorboard and after about 15 minutes of warmth, it starts every time, with gauges working. I have pulled the cluster and the ECU but the connections looked factory perfect. Did you find a solution to your starting issue?
oneModdedGolfR
check your grounds and battery connections
