CSB: Vu - Local Forum n00b Questions Forum Unwritten Rules - New Pope Being Elected
Status
Not open for further replies.
zrickety
The Fixer
New, I cleared the codes before trying anything
I think you're on the track with the harness. I would try moving the relays around and see if that changes anything.
Phur
It is so goddamn cold in my lab at work and I can't adjust the thermostat. I've got a very accurate temp and humidity gauge in here and it reads 68.2°F on the dot.
Lately I've had to keep my coat on and drink coffee or tea every once in a while.
68 feels great outside, but in here it's like a tundra
Lady phur keeps the thermostat set on 63 in the winter. We have to plan ahead for sexy time.
Phur
Friend of mine had no start on his engine and transmission swapped mk4. It ended up being the ground for the clutch safety switch.
jay745
What Would Glenn Danzig Do
This might be peak stupid, but could the float in the new LPFP be wrong? And you have a nearly empty/empty tank?
It's nearly full and the gauge reads it as that. Doubtful that 2 pumps would have the same issue.
Yeah I'm going to throw a new cam position sensor and crankshaft position sensor in before I go hunting for a wiring issue though. The part that makes me think it's one of those 2 sensors is it ran normal for ~15 seconds after I reset the ecu and then shut off abruptly
I don't think it would crank if that's it though 😕
uglybastard
Phur
You’re right. They were isolating the starter.
Acadia18
brat_burner
Can you not read rpm while turning it over? Should be reading a few hundred. A lot of shit will run with no cam sensor
Phur
Acadia18
How Phur and Lady Phur stay warm with the thermostat set to 63°
Status
