Hey everyone!
Wanted to ask if anyone has heard of this issue. My brother just bought a used 2012 golf with a RCD310 that has an audio issue. When the car is off, the audio is "OK". it sounds a tad distorted when you turn up the volume a bit but when the engine is on, the distortion is unbearable.
It sounds like the audio is fluttering when bass kicks in and this only occurs when the engine is on. It occurs on CD/AUX/FM radio so its every source.
Things I still need to try:
1. unplug ground from battery to let car sit with no power to reset.
2. Scan car with vag com to read codes.
3. Pull Radio out and see how it looks in the center stack
4. Check ground points
If all fails, I may buy a 330+ and hopefully its just a bad head unit.
