mikeleemk6
Please pm me ph d if u get some more of the alpine ones man
Instead of cutting the stock wires, has anyone used taps?
DO NOT cut the wires. You just strip the insulation back about a 1/4" to expose the copper wires and then solder. I still have the factory plug intact....safely taped off and secured. Taps are UNRELIABLE.
TPMS has nothing to do with the horn siren. Did you cut into both wires at the same time? When I had someone VAG-COM for the disarm chirp, he found out an error for the horn but was able to clear it. The only time the TPMS warning light came on was when I replaced the Detroits for my current set of wheels.....even though I don't have TPMS sensors mounted on the wheels. Make sure to reset the button, located in the glovebox.
I reset the TPMS using vagcom, i'm wondering if the magnet from the speaker affected the TPMS. I had my horn in the fog area, a little less than 6 inches away from the sensor. So maybe that's what caused it
I also have a 2010 which uses TPMS sensors in each wheel, thus no need for reset button. 2011 and on use the braking system to monitor tire pressure.
Taps SUCK. I used to wire police cars and we NEVER used a tap.
When I did this mod, I had an error code as well, but Vag-Com cleared it. I guess it showed up because I disconnected the siren.
No doubt about those WORTHLESS T-taps. I refuse to use one because it's NOT a direct connection of both wires.....and will eventually fail.
