So if I turn the "V" the other way that will correct my auto adjustment!? I don't want to the manual headlights I like to auto set-up and how the headlights turn with the steering wheel that's one of the reason why I bought this car...can I get the headlight back to the way they were with a lowered car!?
Initially the problem was my installer put the rear sensor with the bend pointing the wrong way. Once I fixed that, I figured it was okay. Took a ride, then did VCDS, took another ride. DO OPTION II IF YOU WANT TO SEE!
Thank you for this DIY, you prolly saved my life..
my experience with coils is you must do the manual adjustment because of the larger drop from stock height than just springs...anyone else?
