How does removing a gti's noise pipe and fitting in a tiguan's noise pipe help reduce potential turbo boost leaks? I thought you were supposed to just remove it and plug it up? If you put in a different noise pipe, then wouldn't it just do the same thing? Sorry :iono: a bit new to this
Look at the pictures again in the first post...you're deleting the "noisemaker"/muffler that sits under the wiper cowl which creates the noise.
The "Tiguan" pipe is the better/OEM solution. On the Passat/Tiguan, they didn't have noisepipes/noisemakers....they just came standard with the ("Tiguan") pipe that I added to my car.
So you delete that pipe on your GTI....get better throttle response, get rid of the "Sea Doo sound", you get to hear the turbo/engine more instead, & you clean up the engine bay....ALL with an OEM look :thumbsup:
If you want to keep it simple/clean/OEM & not have issues with warranty....do the Tiguan pipe. It's a true bolt on mod.
A plug will work, but isn't the best idea (it can blow out...happened on a friend's MKV just over the weekend actually, and can leak too)
