deranged-gp
Hi All
I was plagued with a pink/red light bulb syndrome and since the Golf 5 guide was not sufficient as the bulb design is different in the Golf 6, I decided to create my first DIY guide and I hope it helps.
The pictures are not the best as trying to take pics and do the job by myself was not that easy. Please excuse crappy iPhone pics.
This is what it looks like when your bulb is on its way to the grave
So I purchased new bulbs from our local Lighting expert in South Africa, Jab Sport which cost R800 which roughly converts to $75.
This DIY is not difficult at all and the pictures depict the left hand side of the vehicle where the fuse box is located as this is the difficult side to tackle and the right hand side is much simpler.
Step 1: Disconnect the negative terminal of the battery.
Step 2: Remove the top 2 screws holding the headlight in place, you will not be able to remove the headlight but it moves forward enough to give you clearance to work.
Removing screws
Screws removed and you can see the range of movement you can expect
Step 3: Remove the dust cap at the back of the headlight
Dust cap
Just pull back and it will be released
Step 4: tackling the bulb
Bulb in place (excuse poor image)
get your fingers in there and press highlighted tab you will feel the tab is like a press in switch and push down to remove connector.
Connector removed and from this image you will get an idea of the release tab.
Step 5: Remove Bulb
To remove the bulb turn it 90 degrees to the left and it will release
At this point you can remove the bulb pry the head light forward to give you clearance to remove bulb
Bad Bulb removed
Step 6: Remove Bulb holder
The bulb holder is the black plastic surround, to remove press tab where my thumb is located.
The bulb holder will release
Bad Bulb
Step 7: Transfer the bulb holder to new bulb
New Bulb
When bulb holder on it should look like pics of the old bulb, sorry I did not take any pics of this step.
Step 8: Fit bulb
Before inserting bulb connect the connector, hold bulb with connector end facing the right hand side and pry headlight forward and manoeuvre bulb in, the same way you would do with a desk that is too big for a doorway.
Once you get the bulb in, twist 90 degrees to the right or a down ward action and it should lock into place.
Close up with dust cap and re insert head light bolts.
Repeat the steps on the right hand side which is much easier as there is much more room to work.
Reconnect negative terminal of the battery and test by basking in your new found light.
It took me about 20 mins to do but will be much quicker as I fitted bulb without connecting the connector thinking it would be easier to connect but I was wrong which led me to removing bulb again to get the connector fitted.
Also I wore surgical gloves when handling the new globes as I did not want to damage $75 globes with my fingers.
I hope this helps and if you have any questions I will be more than willing to help.
Removing screws
Dust cap
Step 5: Remove Bulb
Bad Bulb removed
Bad Bulb
New Bulb
Step 8: Fit bulb
