2011 Volkswagen GTI Ko4 2.0T, 6MT, 3-DOOR - MADE IN GERMANY BUILD DATE: 06/10 [JUNE 2010].
ODOMETER READING: 120,000MILES and COUNTING!!!
UNITRONIC STAGE 2+, Ko4 Turbo Conversion, SOUTHBEND STAGE 2 DAILY CLUTCH KIT, BlackForestIndustries weighted gear knob shifter, SPULEN short-shifter, SPULEN 6-Speed Clutch High-Flow Bleeder Block, Fluidampr Engine Crank Pulley, CTS TURBO Street Sport Engine Mount 60 Durometer, AWE Boost Charge Pipe, INJEN cold air intake, 2011 AUDI R8 ignition coils, GoFastBits DV+, TyrolSport DeadSet Rigid Subframe Collar Kit, TyrolSport DeadSet Rigid Subframe Rear [FWD], ST X coilovers, ECS Tuning Street Shield Skid Plate, Ultimate Stage2 Suspension, Upgraded IC, Drilled and Slotted rotors, Akebono brake pads (front), Bosch brake pads (rear), Catless DP, Res Delete, Stock GTI exhaust.
(ALWAYS WORK IN PROGRESS^ = NEVER GIVE UP! [WIN OR LEARN].
“Acknowledging the good that you already have in your life is the foundation for all abundance.”
[SUNK COST FALLACY VIBES $_$]
[FINANCIAL LESSON. DO NOT DAILY THE RACECAR ^_^]
