edward@becautoparts.com
Please see my new add here:
http://golfmk6.com/forums/showthread.php?p=1369118#post1369118
I will no longer continue to update this thread.
Seconds - Headlight lenses will need to be replaced. There was a problem with a batch of lights earlier this year where the UV coating failed within a day of installation. Lights are almost brand new, and new lenses will be provided. You need to bake the headlights to remove and replace the lenses.
Lights only had a few weeks of use, and that is the only issue with them.
Option 3 - Black with LEDs - $400 shipped
Option 4 - Chrome with LEDs - $400 shipped
I only have 2 of each option available.
Add a HID kit to any of the headlights for only $70.[/COLOR]
Please pm me or contact me at: Edward@becautoparts.com to order.[/COLOR]
Specifications:
Depending if you have a Golf, JSW, or GTI, the coding my vary a little, I will gather and post a summary of what coding is needed.
Review can be found here.
http://www.golfmk6.com/forums/showthread.php?t=38153
My old add with reviews are here:
http://www.golfmk6.com/forums/showthread.php?t=40145
Option 1 - Original OEM Look - $500 Shipped or $550 with the HID kit
Option 2 - Black R OEM look - $570 Shipped - available from my supplier
Option 3 - Black R OEM look with 15 LEDs -$550 Shipped or 600 with the HID kit Shipped
Option 4 - Chrome OEM look with 15 LEDs - $550 Shipped or 600 Shipped with the HID kit
To order:
Just pm which option you want, and if you want an HID kit plus your full name and email. Or go to this link on VWVortex, and use the Buy Now button.
Buy Now link is below.
http://forums.vwvortex.com/showthre...up-Buy-New-OEM-Style-LED-Headlights-3-Options
Coding:
for front fog as drl along with LED----
BYTE 18 - is 20
BYTE 14 - is 0B (check bit 1, bit 3)
BYTE 15 - is C4 (check bit 6, bit 7)
BYTE 24 - is E4 (check bit 7)
BYTE 27 - is 24 (check bit 2)
this is the following
LED DRL and FOG light DRL at the same time
to have JUST LED DRL:
same as above with this one exception:
BYTE 14 - is 09 (check bit 3
Quote from MMM.PWR
My setup:
-OEM LED tails w/o fog.
-Euro switch w/o Auto.
-Ed's OEM-like headlights w/ LEDs.
-TRS D2H: Morimoto Elite HID System (EliteD2H)
...Ballasts Morimoto 3Five (35w)
...Kelvin 6000K
...Wire Harness H7
...Wire Harness Type Standalone Can-Bus
Coding: byte 18 is 1F. DRLs are OFF (for the euro switch to work)
Function: LEDs are the parking lights. Meaning I have the flexibility of:
-LED + tails
-LED + tails + fogs
-LED + tails + fogs + low beams / high beams.
That's all I needed to code. No bulb out errors..
Basically, add the HID kit, and do some coding as per above, aim the lights and that is about it.
Specifications:
- Appears identical from the front with the OEM VW Xenon headlights.
- Uses a 10 pin connector, just like your halogen headlights. Does not work with OEM Xenon equipped cars.
- Uses a D2H or D2S HID bulb. A hole is predrilled to run the wiring for your HID kit.
- Easy plug and play, may need to code to remove any bulb out errors because of the HIDs.
- All the other bulbs are included.
- Made by a different factory than the first generation headlights I was selling.
To order:
Coding:
BYTE 18 - is 20
Quote from MMM.PWR
My setup:
...Kelvin 6000K
...Wire Harness H7
-LED + tails
-LED + tails + fogs
