eldiablo1
A few weeks ago while driving on the highway, the car sputtered / died and EPC light came on as well as "!" cruise control fault.
Started the car back up and it drove okay for a few miles, then it started to sputter and got CEL (code P0121 - Throttle Position Sensor). Idle would oscillate wildy (when stopped or moving) from 800 rpm to 2000 rpm with no gas applied.
Was near VW dealer so I drove it there. Dealer replaced throttle body and re-pinned the wires to the throttle body ($1200). Symptoms came back so I returned to VW. They once again re-pinned the wires and said that if it happens again, it's probably due to the fact that I am tuned (APR stage 1). Service manager took the time to tell me he flagged the vehicle as TD1 (like it matters at this point with 82k miles) and said that if it happens again they will need to replace the ECU and wiring harness.
Issue came back very next day.
I replaced coilpacks, cleaned MAP, MAF, and AIT sensors. No difference.
Others have noted similar experience on this site but no definitive root cause or solutions have been communicated. Issue is also documented on other sites as well with no clear answer.
I'm at a loss. If my wife hadn't lost her job recently, I would just trade her in. On a bright note, the weather will be cold for the next few days.
Thoughts?
Conclusion: After several weeks and unfortunate mis-diagnosis from VW, this issue was finally resolved by replacing the engine wiring harness.
Thoughts?
