I haven’t done any logs I have a custom tune from a local tuner I’m running 25psi and it doesn’t even wana break loose in second in the rain I have no missfires no boost leaks my vacuum is 20hg usually, the tuner I had was very conservative the opposite of what I want if it was up to him I’d be running 14psi my tune has never been enough to make my clutch slip once an I have 194k on the car never had an issue with the pcv on this car just got the hs tuning diy clutch an iabed rms I have full bolt ons besides stock intercooler and stock diverter an I don’t think I’m making even 260hp polar fis says I’m making 254What tune are you running?
Are all your maintenance items up to date? Plugs, coil packs, PCV is in good health, DV holding boost, no boost leaks? Have you done any data logging?
Yup I’m in north jersey I have stock latest revision diverter valve the tune I have doesn’t require changing plugs or coils I’d be down to compare tunes I’ve heard people going stage 2 on these cars and needing a clutch my tune makes me feel as if my stock clutch would last forever it really shines more on the top end than anything besides that it’s kind boring are u saying I should skip the eurodyne and just go ko4? My buddy’s mk7 with uni stage one feels faster than my full bolt on stage 2 mk6Eurodyne has been in the game for a while. I have not seen much about them on the forum since I joined but they have solid looking base files. Once you buy the tuning suite you get all the base files up to stage 3 which is nice. APR has a high torque file. My Unitronic tune is solid. You could get a custom Stratified tune with a COBB Accessport.
Stage 2 is anywhere from 240-260HP so that sounds about right.
Do you have a GFB DV+? I'd do some logging before dropping money on another tune but that's me.
You in central NJ? You can compare your car to mine if you want to come toward DE.
My buddy’s r32 also feels faster it’s pretty disappointing considering stage 2 1.8ts should be mk4 r32s and these cars should make more power than 1.8tsYup I’m in north jersey I have stock latest revision diverter valve the tune I have doesn’t require changing plugs or coils I’d be down to compare tunes I’ve heard people going stage 2 on these cars and needing a clutch my tune makes me feel as if my stock clutch would last forever it really shines more on the top end than anything besides that it’s kind boring are u saying I should skip the eurodyne and just go ko4? My buddy’s mk7 with uni stage one feels faster than my full bolt on stage 2 mk6
Yea stage 2s never been that exciting for meI remember when I first went stage 2 and I could boil the wheels off in second. Just save your money and go ko4 thank me later!
How many credits is needed for a stage 2 flash without maestro I bought my cable second hand so I think I need all 8I have the maestro suite. When I flashed my ECU I only had the choice of Stage 1,2 and K04 91 octane base files.(maybe just my ecu code?) If you're going to stay stage 2 it's prob not worth it to get maestro although I've had good results with the base files and currently have a custom Stage 2 file. If you're eventually going K04 too then it might be a good buy.
