My engine's intake timing is getting stuck at -36° when the engine is "cold". It only occurs when I put a load on the engine. If I let it warm up idling then it doesn't get stuck, but until then it can. I data logged the G40 sensor which shows this behavior:
Today I removed the actuator solenoid and manually pushed in the 3/4 way valve and noticed it would stick when fully open, but return if the engine was warm. When cold it just stays in the open position as shown below:
For reference, this is what the valve looks like closed:
Has this happened to anyone else? How hard was it to fix?
