Front and Rear Brembo BBK 330mm with parking calipers
U-20T
Selling my 17z front and rear BBK - they stop unbelievably well and definitely look the part. Does show signs of use, they are used brakes.
What is for sale -
1.Front & Rear 330mm rotors - used
2.Front & Rear calipers - used
3.New set of hub rings for rotors
4.Some misc. Dust boots and caliper parts bought enough to do both front calipers and only ended up using 1 or 2.
5.Hardware to install included
6.SS brake lines
7.Green stuff pads
8. Bembo/Viper parking brake calipers with proper modifications to fit and cable bracket to work with oem cables
These will fit both FWD and AWD vehicles, MK5 and MK6. Same chassis Audi's as well, steel knuckles only.
Front and Rear $2000 + fees and shipping (local pickup free and will meet if you are in the NY tri-state area or just like to drive)
Talguy
Why'd you sell them?
Sebas_theFish
Sorry to revive an old thread but what wheel specs were you running to clear the calipers?
They're Enkei T6S wheels, yes?
Thanks
Sebas_theFish
Yes t6s 18x8.5 et42
No spacers? Plenty of clearance? I'm looking to fit a set of these wheels over some 18z, having a lot of trouble finding wheels which actually clear!
GIACUser
Master Wallet Mechanic
Neuspeed wheels 18in clear 18z without any spacers with 350mm rotors. Clearance is about wheel design on the backside. I made a paper template as Tirerack describes to measure actual wheels or have measurement needed to as wheel manufacturers.
