FS: 2010 GTI Nav 2door black
darkGTI
FS: 2010 GTI Navigation 2dr black
Hey everyone, selling my 2010 GTI with Navigation.
I'm second owner, owned the car since it had 35xxx miles on it.
Car is in perfect mechanical condition, and in good condition exterior wise, has chips on front bumper and hood from hwy commute. Car was garaged all time while I owned it, and hasn't been used primarily on the weekends for past 2 years. It has 108xxx miles on it and 80% of millage is hwy commute to/from work.
Clean title in hand, no accidents.
I also have engine oil reports to prove engine is in perfect health.
Car dyno'd with APR stage 2 and all mods at 253hp/275tq
All maintenance done at KMDTuning and LindenVW. Some highlights:
- engine oil and filter change every 5k miles with Mobil 0W40
- carbon cleaning at 70xxx miles
- tensioner upgrade at 70xxx miles
- transmission upgrade with Wavetrac diff at around 80xxx miles
- car has APR stage 2 with non-testpipe file, so that you can pass emissions in NJ with ease, right now valid to 2020.
- battery replaced last year
- last revision water pump that finally doesn't leak anymore(common problem for mk6), been tested for 2 years now
- latest revision intake manifold(also fixes common problem for mk6)
- perfect alignment
Mechanical Mods:
- APR Stage 2
- Unitronic Custom Intake with CAI
- R8 Redtops and gapped spark plugs
- HPA SS set to 35%, stainless steal bushings from 42DD
- SPULEN Coilovers with adjustable spring and struct high, adjustable dampening, and front camber plates, car is lowered, and can go lower or higher.
- SPM 3'' CBE
- AWE Downpipe
- GFB DV+ with rev G valve
- Neuspeed TOP
- BSH TBP
- Godspeed IC
- HSTuning RSR clutch
- Wavetrac LSD
- Fluidampr Crank Pulley
- PTP Turbo Blanket
- H&R Sway Bar 26mm front sway bar with poly bushings
- 034Motosports 25.4mm rear sway bar with collar set and poly bushings
- TyrolSport Front and Rear Deadset
- NSQBBK with HT10 pads, also read pads are DTC40, stainless steal brake lines and DOT4 high boiling temp fluid.
- Front LCA and Spindles are aluminum from Passat with SuperPro bushings
- SuperPro front and rear adjustable endlinks
- SuperPro antilift kit in the front
- BFI stage 1 trans, engine mounts and torque insert.
Interior mods:
- front leather door and hand rest inserts
- shifter from mk7
- ProClip USA phone holder
Exterior mods:
- canards in the front
- rear spoiler extension
Want 7500$ located in NJ 07010
