$13,750
Price: 13,750.00
Mileage: 115,802
VIN: WVWRF7AJ1DW078800
General condition is very good. Runs strong, does not smoke or leak. A/C blows cold, heater works fine.
All the proper/expensive maint has been done, just need a driver to enjoy the car. Car drives straight, pulls strong (APR Stage 1).
PM me if you have real interest and want more pics / info.
The car is ready to be driven across country. Fly in and drive out ready. I will just do an oil change before you go.
I bought the car from an engineer who drove the car on the freeway daily to work since new. I bought the car 2.5 years ago and have put a little over 7K miles on it. I love the car but I just don't drive it enough. I spent most of my time with the car just refreshing it and adding mods I wanted (not power mods). The car has been in SoCal all the time, I have always garaged it, not sure about previous owner. Car has not been smoked in. Car will come with current smog certificate if sold to Calif resident. Passes smog no problem. Neuspeed intake has CARB#, the APR Stage 1 tune also has a CARB#.
Record of stuff done to car
111,700 miles - new OEM downpipe/cat, new SS brake lines, new fuel and air filter (neuspeed intake), new D DV, new N75 Kit, Turbo chk, no play spins freely.
New Diesel Geek 6 shifter with weight kit.
111,600 miles - Oil and Filter ( Molygen )
111,600 miles - Removed YCW coils - installed new set VWR suspension kit (shocks,springs,bushings)
110,766 miles - installed new headlight set (used) but new like clarity
110,100 miles - new cam follower
110,000 miles - Neuspeed Haldex race controller installed
109.465 miles - oil and filter change
109,100 miles - New RCD330+ reverse camera, headunit and Rockford Fosgate powered 10in sub
108,600 miles - YCW coilovers and 034 rear sway and endlinks
108,000 miles - ECS back hatch pop up kit
108,000 miles - Stock wheels sent in for refinishing, cleaned calipers and new logos
108,200 miles - New windshield and R carpet set
108,400 miles - Hawk HPS 5.0 pads installed and new air filter
108,400 miles - Turned on APR Stage 1 which came with the car but was on stock tune.
107,900 miles - installed stage 2 clutch and single mass flywheel
107,700 miles - alignment performed and rear brake pads and rotors changed. Front wheel bearings replaced.
106,000 miles - oil was changed, spark plugs were replaced, cabin filter was changed, air filter was cleaned and oiled, and I inspected the cam follower for wear, still looks good.
95,000 miles - the front brake pads and rotors were replaced.
94,000 miles - the timing belt and water pump were replaced, brake fluid was replaced, front and rear differential fluids were changed, haldex transfer case fluid was changed, and transmission fluid was changed.
I also put in a new windshield.
Price: 13,750.00
Mileage: 115,802
