These are the lights that come on the Euro model with LEDs installed. They replace the reflectors in the lower part of the doors. You can get a cheap harness to run the required wiring to the door module then with a coding change to activate they work great. Good visibility with the door open to other drivers and lights up the ground under the door so you don't step in something. Also brings a higher end look to the car.
I have a set of 4 for the 4 door model.
Located in Denver
$40 OBO
Located in Denver
$40 OBO
