FS: Twin Intercooler kit with Forge Coupler Adapters
Tony48
Info in my build thread from when I installed a twintercooler.
IIRC I used 4 large (#10 or #12) wood/sheet metal screws from the local hardware store. Ran out to grab them after I had the twintercooler mocked up so I knew what size I needed.
Hold the twintercooler in place, mark through the mounting brackets to the radiator support (thick plastic), remove twintercooler, drill pilot holes, put twintercooler back in place, and install screws. Watch out for the AC lines behind the plastic on the passenger side. They're right where you want to send the screw. If you puncture one you're in for a pricey repair.
