Yeah man, turns out they talk to each other already through the CANbus. So you just need to find your wiring for CANbus drivetrain and it should connect into the Haldex wiring pretty easily. You need hi and lo (or + and -), a ground, and power, if I remember correctly. I tapped into the CANbus right above the pedals, along the bottom of the steering column. I can try to take some pictures if you are interested. DSG would be a little trickier, talk to @U-20T because he did a DSG AND 4motion swap.I'd love to know more about what wiring and programing you needed to complete this. I have a decent idea of the hardware and how it would go together but making the ECU and TCU talk together is something different (I have/want a DSG setup). It looks like you are manual but even so you would have needed to wire in the haldex controller.
Also, it was SUPER easy in VCDS to program it. Literally just a checkbox that says "AWD" that I clicked and it accepted. The ABS module that I had to replace took way more VCDS savvy knowledge than the Haldex programming lol.
