A_Bowers
Moderator
This thread will serve as a comparison thread for ALL GTI logs.
I want this to be as academic as possible, and any posts that are deemed inappropriate will be deleted.
3rd party logging (i.e. members) is preferred, however if a tuner would like to share information (and that alone) that is acceptable as well.
Thanks for everyone who has put forth time and effort to log these files, and looking forward to some hard data to compare.
Conditions for logging information (from this edit forward 4/26/13)
- Software Stage
- Software Provider
- Hardware Modifications
- Conditions of the run (gear that was logged, ambient temperature and altitude).
Baseline/minimum data set to log
You should log the following:
001-1
003-2
003-4
020-1
020-2
020-3
020-4
031-1
054-4
114-4
115-3
115-4
You can use the advanced measuring blocks function in VCDS to log 12 channels at once in turbo mode. (If you have the full hex-can). Don't think the micro can has this feature.
To pull more data from the micro-can cable change these settings.
BLK INT = 25
CHAR INT = 0
- Software Stage
- Software Provider
001-1
003-2
003-4
020-1
020-2
020-3
020-4
031-1
054-4
114-4
115-3
115-4
BLK INT = 25
CHAR INT = 0
