davisharr
So I have been chasing what I think is a bit of a fuelling issue with my 2012 GTI for a while now, and it seems to be getting worse. I have also recently had a cold start missfire issue come up, that I am unsure if it is related, or completely separate. Looking for some advice from the community if anyone would be willing to take a peek, I finally managed to get it on a datalog as it is very inconsistent when it happens.
First off whats done to the car for reference, here is all the engine stuff:
• Stratified K04 Pro-tune 91 Octane
• HPA Motorsports Stage 3 "Extreme Performance" DSG Tune
• APR Carbon Fiber Intake
• Unitronic Factory Mount Intercooler kit
• CTS K04 Turbocharger
• CTS 3" Catted Downpipe
• CTS K04 Turbo Outlet Pipe
• CTS Throttle Pipe
• Bosch 4 Bar MAP Sensor
• Go Fast Bits DV+
The car was tuned for the K04 setup almost 2 years ago, and datalogs all looked healthy before, so something physically with the car seems to have changed. The car has 165,000 Kms as it sits right now.
I was doing a routine datalog a few months back, just to check out the general health of the car, when I noticed that the fuel rail pressure actual, was dipping quite a bit bellow the fuel rail pressure target parameter. At first, I did not think too much of it, as AFR's look good, STFT looks good, and I am not an expert, so perhaps I was over thinking it, so I just let it be. Here is that log to take a peek at...
https://datazap.me/u/mk6gtiguy/march-22nd-intake-manifold-fuel-trim-diag?log=1&data=6-28
When the car was tuned, I was told an important parameter to keep an eye on is STFT, and through Cobbs suite, anything within .85, and 1.15 is probably acceptable, as of recently, every once and a while, maybe 1/10 pulls, I see the STFT peg itself at 1.25, which I have been told means it is adding as much fuel as it can, and is probably an indicator of a fuel system issue. This is when I started really getting concerned, and here I am asking for advice! It does this inconsistently enough that it was very hard to capture on a log, but consistently enough that if I take the car out for a hard drive, it will happen at least once, you can feel it too, the car is way underpowered when this occurs. Here is that log where I did finally catch it today to take a look at: https://datazap.me/u/mk6gtiguy/april-27th-datalog?log=0&data=6-28
Funny enough, when I finally did catch this STFT spike in a log, the rail pressure dip I noticed earlier did NOT happen during this particular pull, but also that its requesting less rail pressure as well.
So far, because I was due for them anyways, I have done the fresh plugs, coil packs, and a fuel filter, as baseline items as a starting point. I also cleaned my MAF, and smoke tested the car for any boost leaks. last carbon cleaning on this car was done 30,000 KM's ago, car has never thrown an actual CEL for any of these issues, The car does feel like it may be down on power and response a bit, but its hard to tell for sure with the butt dyno, so if it is, it must be minor or I am sure I would notice it a lot more. The car still breaks traction in 3rd gear, and most of the time feels quite nice to drive, but something feels off about it, its idling rough, and it feels almost like its working harder to give me the same performance it used to if that makes any sense.
I would love any thoughts from the community and potentially people who know what they are looking at a bit better than me, before I begin to just throw parts at it. Is there any common failure points you might look to on these cars that show these symptoms... etc. I really do appreciate any thoughts, and thank you in advanced!
• CTS Throttle Pipe
• Go Fast Bits DV+
