GTI Sudden misfires - P0300/P130A & P0299 (w/ P1927)
kglewis1
Hello all!
I have a 2011 GTI 6 speed with 183K miles on it. It has several standard mods with an APR stage 1 tune. I typically only use Shell gas, but I used ARCO the other night. After filling up my car, about a mile or two down the road the car started to get really rough like it was misfiring. The check engine light began flashing. I pulled over and changed my tune back to stock and tried to start it again. The car then started rough, and this time I could smell gas. I called up a tow truck to get the rest of the way home. When the driver showed up, he asked if I could drive the car up the ramp. This time, the car wouldn't start. After he took a minute looking around the engine bay, he jumped in and was able to start the car by holding the gas pedal down and cranking the engine. He said the engine was flooded.
The next day, I had the car checked with an AutoZone OBD2 scanner and no fault codes came up despite a check engine light. I decided to buy new plugs since I was due anyway. When I pulled the old plugs, there was black soot on all of them. I put the new plugs in and started up the car. Tah-Dah! Started up and purred perfectly. For about 20 seconds. Then it began jerking again and the check engine light began flashing, and gas could be smelled near the exhaust. I pulled the plugs and they were covered in black soot again, and there was clearly a smell of gas after pulling each plug. Now I was fairly worried, so I called up a buddy of mine and had him bring over his VAGCOM cable...
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 74C93C8717B06F2D96-8020
VINID: 9E69D598745AA129C10830C604A1A1A4F1
5 Faults Found:
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 290271 km
Time Indication: 0
Date: 2017.04.06
Time: 00:03:08
Freeze Frame:
RPM: 1143 /min
Load: 4.7 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 59.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.811 V
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Priority: 0
Fault Frequency: 17
Reset counter: 255
Mileage: 290332 km
Time Indication: 0
Date: 2017.04.06
Time: 02:10:20
Freeze Frame:
RPM: 2662 /min
Load: 62.7 %
Speed: 109.0 km/h
Temperature: 96.0°C
Temperature: 48.0°C
Voltage: 12.954 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 295081 km
Time Indication: 0
Date: 2017.04.06
Time: 19:28:18
Freeze Frame:
RPM: 2225 /min
Load: 36.5 %
Speed: 44.0 km/h
Temperature: 93.0°C
Temperature: 17.0°C
Voltage: 13.462 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 295081 km
Time Indication: 0
Date: 2017.04.06
Time: 19:28:18
Freeze Frame:
RPM: 2225 /min
Load: 36.5 %
Speed: 44.0 km/h
Temperature: 93.0°C
Temperature: 17.0°C
Voltage: 13.462 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 295081 km
Time Indication: 0
Date: 2017.04.06
Time: 20:01:35
Freeze Frame:
RPM: 1385 /min
Load: 40.8 %
Speed: 4.0 km/h
Temperature: 78.0°C
Temperature: 27.0°C
Voltage: 13.589 V
Readiness: 0000 0000
So the first thing we did was pull out a burned up 5A fuse and replaced it. This removed the Aux coolant pump error. I also swapped the PCV(old spare in questionable condition) and coil packs(R8 to OM) just to rule them out, and they seemed fine. I hooked up my air compressor to my turbo inlet and checked for a boost leak. While I couldn't find a leak, and it's been awhile since I tested for boost leaks, I had a feeling that air was escaping the system too quickly. Most of the air was gone in about 20 or so seconds. I also realized that by checking for a boost leak, I believe I pushed gas into my oil, although it's possible some could have already been there.
SO here I am. My though process is that it could be something with the intake manifold, throttle body, carbon build up, or the ECU. I think the ECU is reading lean and dumping gas, but I really don't know. It may also be the turbo, which wouldn't be surprising either. I was hoping for some insight before I go ripping apart the intake manifold. Thanks in advance!
BudgetPhoenix
Fuel injector failure is a very common issue. It will cause a misfire in the affected cylinder, rough running engine and strong fuel smell in the exhaust with smoke. Usually though if you pull the plug you can see the plug wet with gas if they get stuck open but you'll def smell in the fuel in the cylinder as well. I've both had and not had the low fuel pressure code with failed injectors before. I'm betting on Cyl 4 having a bad injector. If you end up replacing it might as well do them all since I've had multiple start failing after 120k miles and its not fun taking the intake manifold back off again.
Also your p0299 prob isn't related since it happened several thousand km earlier according to the vcds readout. Id just clear it for now and monitor if it comes back after fixing your other issue. That code can be caused by multiple different things and it could just be an isolated fluke.
kglewis1
Thanks for the reply!
Since getting to the injectors requires removing the intake manifold, I assume I should just replace this with the revised version. While I'm at it, a carbon cleaning and throttle body cleaning are in order.
While diagnosing fuel injectors is kind of out of the question, is there a way to tell if the intake manifold is bad? I've been reading that the runner flaps tend to go out in some fashion. I also read somewhere that after cleaning out the throttle body, one should do something in VCDS after. Would the APR stage 1 tune be able to do this since it was some throttle body recalibration feature?
When I was putting away my boost leak tester, I noticed quite a bit of oil on it. I know the PCV valve vents oil fumes back into the turbo inlet, but should there be actual oil there? I don't recall actual oil being present last time I boost tested, however it has been some time.
BudgetPhoenix
Usually youll get the P2015 when you have a bad manifold. They have a few ways of failing but really the only visual way you'll see a bad intake manifold is if the flapper arm breaks or pops out causing a vacuum leak and you'll get misfires too. Wouldn't be a bad idea to replace it if you want but its not the end of the world if you don't. I've never cleaned the throttle body when removing the intake manifold. It usually looks fairly clean and id rather not mess with it. There is some vcds force throttle body adaptation feature but ive never had to do it when reinstalling the intake manifold iirc the car does it automatically.
kglewis1
Finally had a chance to open up the car to install the replacement parts and clean out some carbon!
I noticed that two of the intake partitions are damaged. I wouldn't think the damage is critical, but I figured I'd get some thoughts on it.
On the middle partition to the left side you can see that one of the pins is broken. It fits into the gasket on the intake manifold. Two of the partitions have one pin broken.
kglewis1
I got everything put back together and the car is still misfiring. There is some minor white smoke coming out of the back now, may or may not be related to the carbon cleaning. I also swapped the fuel filter before attempting a start. I'll check to see if codes changed hopefully this weekend.
Edit: There's significant white smoke now.
Edit 2: Cylinder 4 still isn't firing. I have gas on the spark plug. I unplugged the fuel injector on 4 and there didn't seem to be much change when I started it. Ruled out the plug and coil pack. A new injector should rule an injector issue out.
