Gunmetal's GTI build thread....its toite like a tiger
GunMetalGTI
Should've started on this a while ago. Its been 2 years since I've had it from new. Going to be updating pics more as I go but here is the list so far along with the rest of the mods I that will be complete within the next year when the project is finished (ehh hem, yea I know its never really done, lol)
Quick note: Some of the "mods" I have listed may not be huge but I listed them anyways just to be thorough as it is a build thread. I did this mainly to help others and give them an idea of how I'm building the car and as kind of a hint to what I also recommend doing. If anyone has any questions please don't hesitate to ask. Thanks for the interest and support in advance.
Current Mileage : 34,600 mi
Motor/Trans:
-APR K04 Turbo Upgrade with UNITRONIC Software, switched over from APR
-Diverter valve relocated with D-revision piston valve
-Test pipe tune
-Unitronic Stage 2 DSG flash
-Modified Ultimate Racing Turbo-back exhaust with titanium tips
-Tried every configuration ever. Currently rear mufflers and two resonators.
-Custom Exhaust cutout with modular DMH Electric cutout (button mounted under dash)
-APR Stage 1 Intake also a modified intake pipe with filter currently.
-BSH Stage 2 Pipe
-BSH Recirculating Catch Can
-BSH Motor mount, transmission mount, and full torque arm mount
-HPA lower trans interlock mount
-Nuespeed Turbo Outlet pipe
-Nuespeed Air Inlet pipe.....Now BSH throttle pipe.
-Forge Boost Tap
-Forge pcv blockoff/fix/africa plate (re-routed BSH can hoses)
-APR Intercooler
-Forge Spacer (sold after 3 months) yea, I know....
-Diverter Valve Revision D
-Removed noise pipe and sound resonator behind dash, also installed block off in firewall
-Trimmed various components of the engine bay
-Semi relocated breather tube for Secondary Air injection
-Red Top Ignition Coils from ECS
-NGK Iridium Plugs
-Pimp-ass magnetic drain plug for the motor and trans as well as magnets for the oil filter (also known as Dimple plugs)
-Upgraded every hose clamp with worm gear clamps from ECS
-Installed Updated fuel filter revision
-Audi R8 oil cap
-Relocated diverter valve directly next to the throttle plate
-Upgraded all boost clamps to T-bolt.
Suspension/Chassis:
-KW V1 Coilovers
-no current FTG, its barely one finger. Going to say 24.6 inches?
-BSH rear sway bar (sold)
-APR front sway bar (set to medium)
-APR rear sway bar (set to firm)
-Nuespeed rear sway bar endlinks
-Stern rear control brace
-Ultra Racing Mid-brace
-Ultra Racing rear 4 point brace
-Diesel Geek Skid Plate
-Upgraded all Sub-frame bolts and installed shim kit
-12mm H and R spacers (not currently running in rear)
-ECS Jack Pad Kit
-Painted and undercoated entire under carriage (black)
-Rolled front fenders and trimmed wheel well liners
Next:
Corner Balancing
White Line Kits -All
Wheels/Tires:
-Privat Legendes 18x8 (Sold)
-Team Dynamics Pro Race 1.2's 18x8 Matte Black
-Dunlop Star Spec Direzza LZ1
-Drag Radial Bridgesone T/A w/
-17'' (2) Pro Race 1.2's
-Winter Setup: Nuespeed Rse05's 17x8 with full sized spare on Cooper Rs3-A tires
Brakes:
-USP Steel Brake Hose kit w/Dot 4 Race fluid
-Soon- Cryo Zinc Black power slot rotors with Hawk performance pads
-Possible- Big brake kit because racecar and it looks awesome
Audio:
-Rockford Fostgate Mono Amp
-Rockford Fostgate 1 Fared Cap
-Optima Red Top Battery
-Added a few extra grounds (Block, Head, Exhaust)
-x2 Uber stealth sub woofer enlosures with shallow mount 10'' pioneer subs and grill
-Modified and re-upholstered rear trunk liner for sub cutout
-Routed bass adjustment knob to front cabin onto driver's seat
Interior:
-Changed every interior bulb over to quality multi-LED bulbs (red and white)
-Removed all rear head-rests
-New South in-vent boost gauge
-Camera windshield mount
-ECS Hatch Pop Kit
-Custom Rear Seat Delete from Euro Kreations
-Dynamat underneath rear seating area and stealth mounted amp and cap
-Rear seat belts removed and tucked
-Mercedes tire iron because racecar
-Dynamatted entire trunk and under rear seat area, every inch. Did about two layers. Added some to hatch as well.
- Full sized Nuespeed 17 inch spare to match the other four.
Vagcom:
-Disable TPMS
-extended turn signal
-windows up and down
-cluster staging
-one more I forget, oh yea, I no longer get a "bulb out" from my city lights (LED)
Exterior:
-No Holes Go Mini Go license plate/tag bracket
-Tinted:
Reflectors
Headlights
Tailights
Wndshield (50%) with blacked out top visor strip
Sunroof (5%)
All other Glass (20%)
Fog lights (tint later removed
-Deluxe Clear Bra 3m paint protection added
-Cancelled rear wiper assembly
-Cancelled washer reservoir and jumped connector
-USP HID Headlight Kit (Running 8000k for reference)
-USP Rear Tag LED lights
-Smoked Side Markers
-PIAA yellow fog light bulbs
-Crystal white LED driving lights
-Di-noc carbon fiber all GTI/VW badging (Later De-badged rear end
-3M paint protection on door and hatch sills
-Badge-less Grill
-3m Flat black vinyl on the Hood, Roof, Rear Hatch, Mirrors and Rear License Plate Inset
-Added lower visor strip to windshield
Videos:
Exhaust revving up vid:
http://youtu.be/vhzRaC3kLYE
chinqutie
It's about time dave! Subbed on this build!:thumbsup:
GunMetalGTI
Reserved...
^^^Haha.....thanks man.
The teaser tonight without the new wheels:
[/IMG]
[/IMG]
Newest Wheels:
[/IMG]
[/IMG]
:thumbsup::thumbsup:
... :needpics:
GunMetalGTI
Last reserve.....Thats enough for tonight....I'll work on pics the rest of the week and hopefully some vids just for this build page since I finally got a phone (Razer Maxx) that kicks ass and makes all this way easier.
Have a happy Memorial Day everyone.
In reply to above......yes, that is obvious but I'm not going to sit here for another hour or two and post more.....lol. It takes more than just one night to get all this together when you have a lot done. If you look, I literally started this thread at 9:15 pm tonight.
I'll have my secretary fax over the details to you in the morning...;)
but don't forget.....your post while not only cluttering the build page, will be worthless when I do post pics so don't forget to update it, thanks.
Update:
[/IMG]
[/IMG]
[/IMG]
GunMetalGTI
Looks good!
:thumbsup::thumbsup:Thanks John......I kinda still miss those wheels. They've only been gone for about a week lol. I'll have a few new pics up today with the new wheels. Haven't seen them on CSG yet.
My methodology behind this build is to build a very track-able daily driver. Its why I switched to a Motorcross style wheel because it goes with the flow of how I've been modifying the car the whole time.
Looking into a rear seat delete next.......
BIG FAT UNCLE PAULY
Dave,
Congrats. , I've been following your countdown and that's a helluva a build thread.
I need to stop out soon on a Wednesday night now that the days are longer.
June 20th is Summer Solstice (longest daylight hours of the year) and falls on a Wedneday this year.
rs999
Test pipe flash? Hmm, I'm guessing MD doesn't emissions test as strictly as here in VA?
BTW, nice mods list. The Unitronic DSG flash is totally worth it :)
GunMetalGTI
Dave,
Thanks. Sounds like a plan. I'm loving this weather. Got a few more odds and ends to tie up this wed. Should have more pics up by then. I'll prob be at the meet this week or next.
Thanks, I'd say it is. Glad you like it. I was just about the first person on this coast to get it as far as I know. They've had one update to it so far.
I've never had a CEL and in MD you will usually just pass if you have no check engine light. Its either that or they let you have at least one code not set for readiness. I'm not really worried either way because if their is an issue I'll just get a new DP or mod the one I have to have a modular setup so I can just put the cat in for testing.
GunMetalGTI
I'm lovin' the car and the Austin Powers reference!
Thanks buddy. I had to throw something in there haha.
also bump for a couple new pics updated.
Waiting to post under carriage shots once I get the car back up on the lift hopefully this week.
chinqutie
one of the best engine bays i've seen in person. :)
GunMetalGTI
Thank ya Thank ya.
UPDATE:
Just ordered a rear seat delete. Should be installed no later than next week.
Also took some good shots under the car while I had it racked up today. I'll try to get them up tonight or tomorrow.
