Helix Depo LED Projector Headlights
Status
Not open for further replies.
I have been running the Depo led headlights for a couple months now. Tonight the drivers side LED drl is not turning off with the car or the parking brake. Have you heard of this before? Do you have any suggestions? I am afraid that since these are wired plug and play drl that something inside the light has shorted out. It has been raining ALL day.
EDIT: does anybody have a wiring diagram on the headlight harness pin out? I wanna check if the drl pin is hot all the time and maybe the problem is on my car rather than the headlight
Hey,
The exact same thing happens with me. My drivers side DRL isnt turning off. Whether I have the car off or on, or whether i have the lights on or off, it will not turn off. I was wondering if you got this fixed and what did you do to fix it. I would like to find an alternative fix than spending $700-$800 on new headlights. please let me know ASAP! they have been on for about a week now and I've tried everything I know how.
Thanks!!
Joseph@OnePerfectDose
Hey,
Thanks!!
This is an indicator the bcm is bad. I believe BMC had this same issue in this thread. This happens on OEM lights as well.
The headlights are just a housing with wires so they are provided power by something beyond the lights.
There is an updated CECM because this is a known issue with the MK6. They fail and cause the lights to remain on. Plug in your stock lights and take it to the dealer and it should be under warranty if your car is still covered.
Image by Sergio_in_SF
Thanks but feels like the led is brighter then the headlights
LED power can be controlled with some VCDS if you dont like the brightness. Most people us an HID kit in the lights as the LED's are so intense.
If you prefer not to run HID, i'd suggest turning down the DRL power. I think it can be done in Central Electronics but can't confirm.
medstudent87
Hello,
I purchased a set of these headlights. First impressions were impressive but I have a couple issues. I paired these with the USP 35w HID kit- 4300k color. I have aimed the lights but they seem to not put as much light in front of the car as my old halogens, it is a dimmer light, and they put allot of light on the sides and in front of the car. I know it is not the aim as if you raise the lights the "dimmer" portions will still blind people. The second issue I have is that I attempted to adjust the horsizontal aim, as the sides are so bright and light up the side road I wanted to try and get it more in the middle, both adjustment screws dont move the lights either right or left. The driver side adjustment screw just makes a clicking noise but is very easy to turn and the passenger side clicks but is under resistance. Please help. I also made sure the return wire was pointing down when I installed the lights. Is the USP kit not bright compared to morimoto? Thanks!
Abbott Martin
Hello,
Upgraded to Morimoto ballasts and my output improved. Remember not to compare to stock beams - these are E-Code not DOT and have a different pattern.
medstudent87
Thanks! I ordered the morimoto bulbs. Did you just replace the ballasts and not use morimoto bulbs? Are your using the 35w ballast still?
Abbott Martin
I replaced the ballasts and cables with Morimotos - have the bulbs but kept the ones Ed sent. They heat up faster, brighter and the output seems to be "cleaner".
medstudent87
Does anyone know how to fix the lateral light adjusters? The adjusters just make clicking noises but not movement to the right or left. I don't see anything blocking or binding the movement.
goose1
Just installed mine, they do click and move a lot less than the up/down adjustment
Sent from my XT1575 using Tapatalk
Status
