Some dealers used to do this over the phone. Need to call around to find one willing to do it though.The RNS-315 in my '12 GTI has some memory corruption and forgets my Bluetooth pairings every now and then. I'm considering replacing it with a used one. Is there a way to get the radio code without going to the dealer?
I believe it's integrated, there's nothing under the seat as far as I know.Does your RNS315 have a built in BT or is the module under the seat like mine is? Replacing the module is easy if so and may fix your issue.
That's a bummer. If I had something to put in my tiguan, which has rns315 with BT built in, I'd offer that up for you. Good luck dude.I believe it's integrated, there's nothing under the seat as far as I know.
When I connect to the radio controller via VAG-COM, it shows a code for a general memory failure.
Well, service guy at the dealer said that it should be specific to the radio itself, not the car, so if I plan on replacing the head unit it's a non issue. Love it when problems turn out to not be problemsThat's a bummer. If I had something to put in my tiguan, which has rns315 with BT built in, I'd offer that up for you. Good luck dude.
If a dealer charges you find another dealer.That is totally worth $12. The dealer will charge you $40.
Every dealer will charge ay least a half hour labor for this. Years ago you could call the parts dept with the vin and they'd give it to you but vw cracked down on this requiring the car to be physically present to confirm the radio isn't stolen. If you bring a radio from another car you'll need the vin from the original car so they can verify it's not reported stolen.If a dealer charges you find another dealer.
Recent experience with dealer and yes on fee, plus car with radio installed had to be present for reason you stated. Just trying to give away my oem headunit for free turned out to be easier to just dump it.Every dealer will charge ay least a half hour labor for this. Years ago you could call the parts dept with the vin and they'd give it to you but vw cracked down on this requiring the car to be physically present to confirm the radio isn't stolen. If you bring a radio from another car you'll need the vin from the original car so they can verify it's not reported stolen.
I called all the dealers in my area. $100 was the norm, but one quoted $40 so I jumped on it.If a dealer charges you find another dealer.
